What is the boundary layer (aerofoils)?
In summary, the boundary layer is a thin layer of fluid near a surface where the velocity changes smoothly from zero at the surface to the free-stream velocity. This is due to the viscous effects between adjacent streamlines and is known as the "no slip condition". The boundary layer is important in understanding fluid flow over aerofoils and can be found in various papers and journals by searching online. According to Schlichting's Boundary-Layer Theory, the boundary layer is defined as a very thin layer near the body where the velocity gradient normal to the wall is large and the viscosity of the fluid plays a significant role.
BlueCB
Can someone please explain to me the nature of the boundary layer and its effects on fluid flow over an aerofoil?
Thanks,
When a fluid with nonzero viscosity (essentially any fluid) will tend to "stick to" the wall over which it is passing. This means that at the wall, the velocity is zero relative to the wall. For any fluid moving relative to the wall, there will be some region where the velocity of the fluid transitions smoothly from zero at the wall up to the free-stream value far away from the wall. The region between the wall and the point where the fluid velocity assumes the velocity of the free stream is called the boundary layer.
Likes 1 person
Boudary layer: As the name implies some meaning to this term (i.e)it is a thin layer where velocity gradients exists inside this layer. This velocity gradients exists because of the viscous effects between two adjacent streamlines. At the surface of the airfoil the velocity is zero which is referred to as "No slip condition". Above this boundary layer the velocity will be equal to the freestream velocity...You can find lots of papers and journals regarding BL...Just google it.
Definition from Schlichting's Boundary-Layer Theory:
Boundary Layer: A very thin layer in the immediate neighbourhood of the body in which the velocity gradient normal to the wall, θu/θy, is very large. In this region the very small viscosity, μ, of the fluid exerts and essential influence so far as the shearing stress τ=μ(θu/θy) may assume large values.
Related to What is the boundary layer (aerofoils)?
1. What is the boundary layer on an aerofoil?
The boundary layer on an aerofoil is the thin layer of air that forms on the surface of the wing as it moves through the air. This layer is where the air closest to the surface of the wing experiences a change in velocity and pressure compared to the undisturbed air further away from the wing.
2. How does the boundary layer affect the performance of an aerofoil?
The boundary layer has a significant impact on the performance of an aerofoil. It affects the lift, drag, and overall aerodynamic efficiency of the wing. A thicker boundary layer can increase drag and reduce lift, while a thinner boundary layer can improve lift and reduce drag.
3. What causes the boundary layer to form on an aerofoil?
The boundary layer is caused by the difference in velocity between the air close to the surface of the wing and the undisturbed air. As the air flows over the curved surface of the wing, it must travel a longer distance, resulting in a decrease in velocity and an increase in pressure. This difference in velocity and pressure creates the boundary layer.
4. How does the shape of an aerofoil affect the boundary layer?
The shape of an aerofoil can significantly influence the boundary layer. A thicker, more curved aerofoil will create a thicker boundary layer, while a thinner, flatter aerofoil will create a thinner boundary layer. The shape also affects the transition of the boundary layer from laminar (smooth) to turbulent (chaotic).
5. What techniques are used to control or manipulate the boundary layer on an aerofoil?
There are several techniques used to control or manipulate the boundary layer on an aerofoil. These include changing the shape of the aerofoil to reduce drag, using suction or blowing to reduce the thickness of the boundary layer, and adding small protrusions or dimples to the surface of the wing to control the transition from laminar to turbulent flow.
  • Mechanical Engineering
11K
  • Aerospace Engineering
