What is the by-product when skeletal cells respire anaerobically ?
  • Thread starter no idea
  • Tags
    Cells
In summary: In yeast, it will be alchohol. In summary, the by-product when skeletal cells respire anaerobically is lactic acid or alcohol, depending on the organism. This process, called fermentation, occurs after glycolysis in the absence of oxygen and produces a small amount of ATP for energy.
no idea
93
Biology news on Phys.org
I think you are asking about skeletal muscle cells and if so the conversion of glycogen to glucose and then glucose to pyruvic acid creates 2 ATP molecules for energy (all under anaerobic conditions). The pyruvate is rapidly converted to lactic acid if no O2 is around for the aerobic side of the equation, thus this lactate could be considered a by-product.
thx
Asking this question because i heard my friend saying that skeletal muscle cells give alcohol when respire anaerobically.
DocToxyn is correct, and the process of anaerobic process is known as glycolysis.
Yes, DocToxyn is correct. However, glycolysis is the first step of cellular respiration, both aerobic and anaerobic (it uses NAD+ instead of oxygen as the electron acceptor, so can be an oxidative reaction even in the absence of oxygen).
Under anaerobic conditions, the product of glycolysis, pyruvate, is utilized in fermentation. In a muscle cell (as well as fungi and some bacterial cells), this would be lactic acid fermentation, as DocToxyn pointed out. The other possible fermentation reaction is alcohol fermentation, as is carried out by yeast and some other bacterial cells. This may be where the confusion came from because both processes are called fermentation, which refers to anaerobic respiration, but the end product is different in different cell types, so you name the process according to the end product.
no idea said:
thx
Ahh, if only that were true, "runner's high" would have a whole new meaning. :wink:
well water is alcohol..
Ah, thanks Moonbear the clarification/extension.. I also noticed a blunder in my original post "process of anaerobic process", which should read "process of anaerobic respiration". So is glycolysis the only anaerobic pathway for respiration in muscle cells? That's more what I was thinking about, lactic acid production due to a lack of oxygen, since the OP mentioned skeletal muscle cells.
In this thread I provided links for sites with animations of the three steps of aerobic respiration. In anaerobic respiration (absence of oxygen), instead of going from glycolysis to the Krebs cycle, you go from glycolysis to fermentation and can get either lactic acid or alcohol as a by-product. In skeletal muscle, it will be lactic acid.
FAQ: What is the by-product when skeletal cells respire anaerobically ?
What is anaerobic respiration?
Anaerobic respiration is a type of cellular respiration that occurs without the presence of oxygen. It involves breaking down glucose to produce energy without using oxygen as the final electron acceptor.
How do skeletal cells respire anaerobically?
Skeletal cells respire anaerobically by breaking down glucose through a process called glycolysis. This process occurs in the cytoplasm and does not require oxygen. The end products of glycolysis are then used to produce energy in the absence of oxygen.
What is the by-product of anaerobic respiration in skeletal cells?
The by-product of anaerobic respiration in skeletal cells is lactic acid. This is formed when pyruvate, the end product of glycolysis, is converted to lactate by the enzyme lactate dehydrogenase.
Why is lactic acid produced during anaerobic respiration in skeletal cells?
Lactic acid is produced during anaerobic respiration in skeletal cells because there is a limited supply of oxygen available. Without oxygen, the cell cannot continue the process of cellular respiration and must rely on anaerobic pathways to produce energy.
What happens to the lactic acid produced during anaerobic respiration in skeletal cells?
The lactic acid produced during anaerobic respiration in skeletal cells is either used as a source of energy by other cells or is converted back to glucose in the liver. This process is known as the Cori cycle and allows for the recycling of lactate and glucose in the body.
