What is the Cardinality of the Set of Ordered Bases of a Finite-Dimensional Vector Space over a Finite Field?
  • MHB
  • Thread starter Chris L T521
In summary, cardinality refers to the size of a set, a vector space is a collection of vectors that can be added and multiplied, an ordered basis is a set of linearly independent vectors that span a vector space, a finite field is a mathematical structure with a finite set of elements and two operations, and the cardinality of the set of ordered bases of a finite-dimensional vector space over a finite field is determined by the number of elements in the field raised to the power of the dimension of the vector space.
Chris L T521
MHB
915
Here's this week's problem.
Problem: Let $V$ be a finite-dimensional vector space over a finite field $\mathbb{F}_q$ of cardinality $q$. Let $\mathscr{B}$ be the set of ordered bases of $V$. Compute the cardinality of $\mathscr{B}$, as a formula involving $q$ and $\mathrm{dim}(V)$.
No one answered this week's question. You can find my solution below.
Let $B$ be any basis of $V$ and $d:=\dim V$. First choose a non-zero vector in $V$. Since every vector in $V$ can be written as a linear combination of elements in $B$ with coefficients in $\mathbb{F}_q$, there are $q^d-1$ nonzero vectors in $V$. Now assume we have chosen linearly independent vectors $v_1,v_2,\dots, v_n$ for $n<d$. Then $\#\mathrm{Span}\{v_1,\dots,v_n\}=q^n$, and there are $q^d-q^n$ choices for vectors not in the span of $v_1,\dots, v_n$. This process must continue until we have $\dim (V)=d$ linearly independent vectors. Therefore
\[\#\mathscr{B}=\prod_{i=0}^{d-1}(q^d-q^i).\]
FAQ: What is the Cardinality of the Set of Ordered Bases of a Finite-Dimensional Vector Space over a Finite Field?
What is the definition of cardinality?
Cardinality refers to the number of elements in a set. It is a measure of the size or magnitude of a set.
What is a vector space?
A vector space is a mathematical concept that describes a collection of objects (vectors) that can be added together and multiplied by a scalar to form new vectors. It is a fundamental concept in linear algebra and has applications in various fields of science and engineering.
What is an ordered basis?
An ordered basis of a vector space is a sequence of vectors that can be used to represent any vector in that space. It is a set of linearly independent vectors that span the entire space.
What is a finite field?
A finite field is a mathematical structure that consists of a finite set of elements and two operations, addition and multiplication, which satisfy certain properties. It is also known as a Galois field and has applications in coding theory, cryptography, and algebraic geometry.
How is the cardinality of the set of ordered bases of a finite-dimensional vector space over a finite field determined?
The cardinality of the set of ordered bases of a finite-dimensional vector space over a finite field is determined by the number of elements in the finite field raised to the power of the dimension of the vector space. In other words, if the finite field has q elements and the vector space has n dimensions, then the cardinality of the set of ordered bases is q^n.
