- #36
Drakkith
Mentor
- 23,037
- 7,421
Wanted said:You can't have things moving away from you in a direction in which things are not occupied. If you happened to be there. Sure you'd have things moving away from you in one direction... but not every. Edge simply means you are ahead of anything else in the direction you are traveling and will cease to see anything new in the direction you're traveling because you have already passed everything or were already ahead to begin with.
Again, there is no edge. You can travel as far as you like but you will never find an edge. You will only keep finding matter in all directions.
Wanted said:There has to be an expanding edge because the universe is constantly expanding in unoccupied space. There is no absolute center because center has many definitions and fulfilling these definitions requires indeterminable data or doesn't have a center.
The universe is not expanding into unoccupied space. The distance between all unbound objects is simply growing larger over time.
Wanted said:The first link explains why the TBB is not a point, which is not a claim I am making.
The second links explains a list of things only a few of which I can find directly relevant (would help if you were specific). The relevant section I found was http://www.astro.ucla.edu/~wright/nocenter.html which states there is no center based on the predication that center is defined as a point in which everything moves away from which I agree it does not have.
What you claimed, and what you claim that you've claimed, do not match. Your explanations require that the universe expanded outwards from a single point, whether you realize they do or not.
