What is the centripetal acceleration of the bob-sleigh?
In summary, the sleigh must have a centripetal acceleration of 15.4 m/s^2 at the point B in order to enter the first corner at the correct angle.
Haveagoodday
43
At the Olympic bob-sleigh competition, a new (I admit, fairly boring...) track
has been built, as drawn in the figure. It is composed of straight lines with
lengths as indicated in the figure and 90.0 degree turns, each with the same
radius of curvature r1 = r2 = r3 = r4 = 40,0 m. The track slopes evenly
downwards all the way down (including through the corners), a total altitude
drop of 100 m over a distance of 1.50 km, so between the starting point (A)
and the end point (E). You may assume that the ice is frictionless. There is
gravity, g = 9:80 m/s2.a) Assuming that the sleigh starts from rest at (A), what is its speed when
it reaches (B)? How long does the whole run take (from A to E)? (To keep
it simple, we will ignore that bobsleighs are usually pushed to begin with by
the crew. Here, it is just sliding under the effect of gravity).
b) Consider the point when the sleigh enters the first corner (B). What is the
required centripetal acceleration, that the track has to provide immediately
after (B)? What is the tangential acceleration during the turn? What is the
required centripetal acceleration immediately before reaching (C)?
(c) At what angle with the horizontal does the sleigh need to slide up the
side of the track in order to have the required centripetal force at (B) and
(C)?
d) What is the total acceleration of the sleigh as it comes out of the fourth
corner (immediately before (D))? In units of g?
a) My solutions for a:
In every meter the altitude drops down 0.06666667 m
in 200 m it drops down = 13.3 m
so θ= 4
v=sqrt(2gdsinθ)=16,5m/s from A to B
Time taken from A to E:
t=sqrt(2d/gsinθ)= 66,2 seconds
b) centripetal acceleration immediately after B:
ac=v^2/r= 6,8 m/s^2
tangential acceleration:
a=sqrt(ar^2+at^2)
9.80m/s^2=sqrt(6.8^2+at^2)
at=sqrt(6.8^2-9.80^2)=12m/s^2
centripetal acceleration before reaching C:
ar=sqrt(-9.80^2+12^2)= 15,4 m/s^2
c) angle required:
-mgcosθ=macsinθ
tanθ=-g/ac=-55 degrees
d) total acceleration
a=sqrt(ar^2+at^2)=sqrt(15,4^2+12^2)=19,5 m/s^2
All answer are appreciated!
Um... What part are you having trouble with? You seem to have answers for every part.
By the way, it really looks like you just copied down the answers from the "back of the book." I know that isn't what you did, you just forgot to put in your work. So maybe you could edit it and add some of the steps?
Hello, it might look like i did copy the answers, but i can promise you i didn't. The reason we i posted this is just if somebody have the time to correct me if my answers are wrong, plus these problems aren't from the book neither from the internet.
I agree with you on your answers in a. The rest is wrong, from my point of view. You forgot that your slope is going down at 4 degrees ALL the time.
Ok, thank you for your answer, but could you give me some guidelines?
First, I would not determine the angle as such. You can go straight from the "1 in 15" slope to whatever else you need without finding the angle or invoking trig functions. Just use Pythagoras. That minimises the accumulated errors.
It is not completely clear whether the 1 in 15 relates to drop per horizontal distance or drop per distance down slope, but the difference is too small to matter here.
What is the distance from B to C?
After C, where, exactly, do you think the 200m shown takes you to?
ac=v^2/r= 6,8 m/s^2 -this one is right also...
Here it goes wrong.
a=sqrt(ar^2+at^2)
Make a diagram with forces. Tangential acceleration is in the same direction as speed (look up same for the circle). Radial acceleration will be 0.
By showing sum of forces for x and y directions, you will arrive to an equation that in the end will look like at=g*sintheta.
For the last part of b) ac depends on V. In the point C, what speed did the sleigh get, if it is constantly accelerating at a downwards angle of 4 degrees?
I repeat my advice regarding the angle. By calculating the angle as 4 degrees then using that number as input to trig functions you introduced inaccuracy. The 16.5m/s is a little off. Likewise the time for the whole descent (about 2% off).
a=sqrt(ar^2+at^2)
What makes you think the total acceleration is g here?
Suppose, for the moment, that the curved corners are level instead of continuing to descend. What would the tangential acceleration be?
Was quoting haveagoodday here. These are his functions.
Yes, sorry. Consider my replies as directed to @Haveagoodday
I also have a question about this problem, if you find an Acceleration i task a), can you use it in the other tasks? I have done that, but not sure if its right, because wouldn't you get a new acceleration out of every corner? . (srry if my question may seem a bit unclear, was hard to explain)
In practice, the track would have to be banked (increasingly) through each corner so that the sled stays on track without friction. You can consider the normal force in two components at a point on a corner: a horizontal component and a component in the vertical plane. The horizontal component supplies the centripetal acceleration, while the vertical plane component provides the tangential acceleration.
According to the question statement, that vertical plane component will have the same angle to the vertical throughout the track, so the tangential acceleration should be constant.
how did you get teta = 4, should it not be 3,82 ?? when sin-1(13.33/200)=3.82
Thanks!
well i did it this way tan-1(13.3/200)=3.81 and then i rounded it up to 4.
Likes coffeemanja
... which was a bad idea, too great an error.
Anyway, as I keep pointing out, there is no benefit in finding the angle. All you need is the fall rate, 1 in 15.
The question is not clear as to whether the 1.5km is horizontal distance or distance along the slope. Probably the second, in which case if yio wanted to find the angle it would be sin-1, not tan-1. Being such a small angle it makes only a tiny difference.
Related to What is the centripetal acceleration of the bob-sleigh?
The centripetal acceleration of the bob-sleigh is the acceleration towards the center of the circular path that the bob-sleigh is moving along.
How is the centripetal acceleration of the bob-sleigh calculated?
The centripetal acceleration can be calculated using the formula a = v^2 / r, where a is the centripetal acceleration, v is the velocity of the bob-sleigh, and r is the radius of the circular path.
What factors affect the centripetal acceleration of the bob-sleigh?
The centripetal acceleration of the bob-sleigh is affected by the speed at which the bob-sleigh is traveling, the radius of the circular path, and the mass of the bob-sleigh.
How does the centripetal acceleration of the bob-sleigh relate to centripetal force?
According to Newton's second law of motion, the centripetal force is directly proportional to the centripetal acceleration. This means that as the centripetal acceleration increases, so does the centripetal force required to keep the bob-sleigh moving along the circular path.
Can the centripetal acceleration of the bob-sleigh be negative?
No, the centripetal acceleration of the bob-sleigh cannot be negative. Since it represents the acceleration towards the center of the circular path, it is always positive and directed towards the center of the circle.
