What is the change of momentum of the ball?
In summary: There is a third force involved as well. (It's not the normal force, because the block is not accelerating in the normal direction.)3. There is only one force on the bottom block in your free body diagram.4. The blocks are not accelerating in the y direction, so the forces in the y direction must balance. (Right now you have a net force in the y direction on the bottom block.)5. There is a force of friction acting on both blocks, not just the bottom one.I think you need to think more about the physical forces acting on each block before trying to write the equations.
underduck
1. A 0.095 kg tennis ball is traveling 40 m/s, hits a wall and travels in the opposite site direction it came from. The bounced leaving the wall with a speed of 30 m/s.
a. What is the change of momentum of the ball?
b. If the time contact is 20ms, find the impulse force.
m1= 0.095 v1= 40 m/s
m2= 0.095 v2= -30 m/s
My equation for:
a. change of momentum= (m1 x v1) - (m2 x v2)
(0.095 x 40) - (0.095 x -30) = 6.65 kg m/s
is this equation right?
b. i have no idea. i need some help here please :)
a) A change in momentum would be = momentum after - momentum before. It's also a vector quantity so is the ball going in the same direction afterwards?
b) Impulse = Change in momentum = force * time
Yes, correct.
For (b), see the post by CWatters.
p.s. Welcome to Physics Forums.
Redbelly98 said:
Yes, correct.
Answer for
B. F= (mv - mu)/t
= (0.095 x -30) - (0.095 x 40) / 20
= -0.33 N
is that correct ?
hehe my first time doing physics. thanks for the help guys!
I dissagree with the answer you give for a)
The change in momentum = MV2 - MV1
Therefore the change
= (0.095 * -30) - (0.095 * 40) = -2.85 - 3.8 = -6.65 kg.s-1
Note the minus sign.
For b)
The impact force = change of momentum / time (in seconds)
= -6.65/(20 x 10-3)
= -332.5 N
Negative because the applied force is in the opposite direction to the initial direction the ball was traveling in.
CWatters said:
For b)
= -6.65/(20 x 10-3)
= -332.5 N
I got it for the first question.
for the second one there is one thing I'm confused there:
(20 x 10-3)
why do i need to add 10-3 ?
thank you. i really appreciate your help, making things easier for me.
I have another question on this Impulse and Momentum topic.
Two identical blocks, each mass 10kg, are used in an experiment. The First is held at rest on 20° incline plane 10m from the second, which at rest at the foot of the plane. the one descends the incline, slams into and sticks to the second, and the sail off together horizontally. given μk= 0.35, g 9.8 m/s2
1. Find the velocity of the first block just before it hit the second block
2. Find the velocity after the impact
3. Find the change of kinetic energy
The contact time is 20ms not 20s.
20ms = 20 * 10-3seconds.
Which bit are you stuck on? Have you drawn a diagram showing the forces on the first block?
I'm stuck from the first question. getting a lil bit confused on how to use the equation. maybe you can explain.
Here i attach the free body diagram for the question. thank you
There are problems with your free body diagram:
1. There is no applied force Fapp. (There would have been a force holding the block in place initially, but then it is released and allowed to slide down the incline.)
2. There are other forces involved that you did not draw for the top block. The "μk" and "g" suggest what two of those forces are.
Related to What is the change of momentum of the ball?
1. What is momentum?
Momentum is a measure of an object's motion, determined by multiplying its mass and velocity. It is a vector quantity, meaning it has both magnitude and direction.
2. How is momentum related to an object's mass and velocity?
The momentum of an object is directly proportional to its mass and velocity. This means that as either mass or velocity increases, the momentum of the object also increases.
3. What is the unit of momentum?
The unit of momentum is kilogram-meter per second (kg∙m/s) in the SI (metric) system. In the imperial system, the unit of momentum is pound-feet per second (lb∙ft/s).
4. What is the change of momentum of an object?
The change of momentum of an object is the difference between its initial momentum and its final momentum. It can be calculated by subtracting the initial momentum from the final momentum.
5. How is the change of momentum of a ball related to force?
According to Newton's second law of motion, the change of momentum of an object is equal to the force acting on the object multiplied by the time over which the force acts. This means that the greater the force acting on the ball, the greater its change in momentum will be.
