What is the coalescence factor?
  • Thread starter Waxbear
In summary, the article discusses the production of deuteron and triton particles in Pb+Pb collisions and introduces the coalescence factor, which is used to calculate the likelihood of light clusters forming. A is the mass number of the cluster, R_np is the ratio of neutrons to protons involved in the collision, gamma is the Lorentz factor related to the velocity of the cluster, and V is the volume of particles at freeze-out. The units of s_A, which is part of the coalescence factor, are still uncertain. The coalescence factor is expected to be unitless, but a similar equation in another article suggests it has dimensions of mass times momentum.
Waxbear
42
I am reading an article on experimental nuclear physics. The article is about deuteron and triton production in Pb + Pb collisions. In the article they mention the coalescence factor which is given by:
[itex]B_{A}=A\frac{2s_{A}+1}{2^{A}}R^{N}_{np}\left(\frac{h^{3}}{m_{p}\gamma V}\right)^{A-1}[/itex]
The coalescence factor has something to do with the formation of light clusters A(Z,N). So A is the mass number of the cluster, the R_np thing is the ratio of neutrons to protons participating in the collision, gamma is just the lorentz factor related to the velocity of the cluster and V is the volume of of particles at freeze-out (after hadronization, when there are no more strong interactions between the nucleons). I don't know what s_A is though. I have worked out the units for A = 2 to be:
[itex]s_{A}\cdot \frac{ev^{2}s}{m}+\frac{ev^{2}s}{m}[/itex]
But i don't know the units of s_A. I was hoping for this to turn out unit-less, since it could then be interpreted as a sort of probability of a cluster A(Z,N) to form. Now I'm not sure what it is.
I apologize if this post was supposed to go in homework. Technically it is a sort of homework question, since i am supposed to present the article as an exam tomorrow. But i figured that there was a bigger chance that someone could help me with this on the HEP board.
It has to be unitless, since you add 1 to it.
Of course, i didn't even consider that. Okay, so i guess the coalescence factor has dimensions of:
[itex]\frac{ev^{2}s}{m}[/itex]
I'm still not sure exactly sure about what the coalescence factor is though.
Where does your formula come from? I found a similar one in Coalescence and flow in ultra-relativistic heavy ion collisions (pdf, equation 6.2), but that uses (2pi)^3 in the nominator of the brackets.
I don't see how masses cancel in the equation.
A cross-section (1/m^2) or a dimensionless fraction would be a nice result, and I think c=1 is implied.
I probably did something wrong when i tried to find the dimensions and yes i think you are right that c = 1 is implied. I got the equation from an old article called "Deuteron and triton production with high energy sulphur and lead beams". It's from 2001, so you might not be able to find it on the internet anymore.
Yes a cross-section or a fraction would be very nice, however, i found a plot later in the article where B_2 has dimensions:
[itex]Gev^{2}c^{-3}[/itex]
Which is mass times momentum. Weird.
Related to What is the coalescence factor?
The coalescence factor is a measure of how efficiently particles come together to form larger droplets or particles. It is used in various fields such as atmospheric science, chemical engineering, and biotechnology.
How is the coalescence factor calculated?
The coalescence factor is typically calculated by taking the ratio of the actual rate of coalescence to the maximum possible rate of coalescence. This can be expressed as a percentage or a decimal value.
What factors affect the coalescence factor?
The coalescence factor can be affected by various factors such as particle size, temperature, and surface tension. Additionally, the presence of impurities or surfactants can also influence the coalescence factor.
Why is the coalescence factor important?
The coalescence factor is important in understanding and predicting the behavior of particles in various systems. It can also impact the efficiency of processes such as filtration, sedimentation, and emulsion stability.
Can the coalescence factor be controlled?
Yes, the coalescence factor can be controlled by adjusting the parameters that affect it, such as particle size, temperature, and surface tension. Additionally, the use of additives or surfactants can also help control the coalescence factor in certain systems.
  • Other Physics Topics
