vande060
- 186
y" + 6y' + 9y = 1+x
r^2 + 6r + 9 = 0
(r +3)^2 = 0
r = -3
I thought the yc = c1e-3x + c2e-3x
buy my prof says yc = c1e-3x + c2xe-3x
why is the x in there?
I agree with your prof. For a 2nd order, homogeneous differential equation, the solution space is two dimensional, which means that the complementary solution is all linear combinations of two linearly independent functions. Your complementary solutions is the same as (c1 + c2)e-3x = Ke-3x.vande060 said:Homework Statement
y" + 6y' + 9y = 1+x
r^2 + 6r + 9 = 0
(r +3)^2 = 0
r = -3
Mark44 said:Yes.
The complementary equation for a differential equation is a solution that is added to the particular solution to obtain the general solution. It is also known as the homogeneous equation.
To find the complementary equation for a differential equation, you need to set the right-hand side of the equation equal to zero and solve for the unknown function. This will give you the general solution of the complementary equation.
The complementary equation is a solution that is added to the particular solution to obtain the general solution of a differential equation. The particular solution is a specific solution that satisfies the given initial conditions.
Yes, it is possible to have multiple complementary equations for a differential equation, as long as they satisfy the same differential equation and initial conditions.
The complementary equation is important because it helps us find the general solution of a differential equation, which includes both the complementary and particular solutions. This allows us to find the specific solution that satisfies the given initial conditions.
