What is the condition for $E$ in the time-independent Schrödinger equation?
  • MHB
  • Thread starter Ackbach
  • Tags
    2015
In summary, the time-independent Schrödinger equation is a fundamental equation in quantum mechanics that describes the behavior of a quantum system over time. It is used to calculate the energy levels and wave functions of a system. The difference between the time-dependent and time-independent Schrödinger equation is that the former takes into account the change of a system over time, while the latter assumes that the system's properties do not change with time. The condition for E in the time-independent Schrödinger equation is that it must be the eigenvalue of the system, and the equation is solved by finding the wave function that satisfies it. The time-independent Schrödinger equation has significant physical significance as it allows us to understand
Ackbach
MHB
4,155
92
Here is this week's POTW:
The time-independent Schrödinger equation in one spatial dimension is
$$E \, \psi(x)=\left[-\frac{\hbar^2}{2m} \, \frac{d^2}{dx^2}+V(x)\right]\psi(x).$$
Show that $E$ must exceed the minimum value of $V(x)$ for every normalizable solution.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
No one answered this week's POTW. My solution is below:
We can rewrite the Schrödinger equation as
\begin{align*}
E \, \psi(x)&=\left[-\frac{\hbar^2}{2m} \, \frac{d^2}{dx^2}+V(x)\right]\psi(x) \\
-\frac{\hbar^2}{2m} \, \frac{d^2 \psi}{dx^2}&=(E-V) \, \psi \\
\frac{d^2 \psi}{dx^2}&=-\frac{2m}{\hbar^2} \, (E-V) \, \psi.
\end{align*}
If $E$ is not greater than the minimum of $V$, then $\psi$ and its second derivative must have the same sign. Assuming sufficient differentiability (which we can get from physical arguments), this would mean a non-normalizable wave function, as the area under $|\psi|^2$ must be infinite. (N.B. that the norm we are talking about is the $L^2$ norm: $\displaystyle\|\psi\|_2=\int_{-\infty}^{\infty}|\psi|^2 \, dx.$)
FAQ: What is the condition for $E$ in the time-independent Schrödinger equation?
What is the time-independent Schrödinger equation?
The time-independent Schrödinger equation is a fundamental equation in quantum mechanics that describes the behavior of a quantum system over time. It is used to calculate the energy levels and wave functions of a system.
What is the difference between the time-dependent and time-independent Schrödinger equation?
The time-dependent Schrödinger equation takes into account the change of a quantum system over time, while the time-independent Schrödinger equation assumes that the system's properties do not change with time.
What is the condition for E in the time-independent Schrödinger equation?
The condition for E in the time-independent Schrödinger equation is that it must be the eigenvalue (or energy level) of the system. This means that the system's wave function must satisfy the equation in order for it to represent a valid energy state.
How is the time-independent Schrödinger equation solved?
The time-independent Schrödinger equation is solved by finding the wave function that satisfies the equation, along with the appropriate boundary conditions. This can be done analytically for simple systems, but for more complex systems, numerical methods are often used.
What is the physical significance of the time-independent Schrödinger equation?
The time-independent Schrödinger equation has significant physical significance as it allows us to calculate the energy levels and wave functions of quantum systems, which are crucial in understanding the behavior of matter at the atomic and subatomic level.
