What is the correct math notation for the Coulomb Barrier?
In summary, the conversation is about finding the correct mathematical symbol for the radius of the Coulomb Barrier. The person is seeking help in finding the symbol and also clarifying the meaning of the equation U=-kQ/r. They also mention that this is not for homework but for editing a friend's peer reviewed paper. They share a webpage they found but it does not explain the meaning of U. They then ask again for the correct symbol and apologize for their questions.
seattle.truth
I am trying to find out what is the correct way to write the mathematical demarkation for the Coulomb Barrier.
You know, if I wanted to write the symbol for the radius of the coulomb barrier.
If anyone could show me it in the correct font that would be great.
NO, this isn't for homework, I am helping edit a friend's peer reviewed paper.
Thanks.
Anybody? Bueller? Bueller?
Thanks in advance.
Uh, is it not just U=-kQ/r?
Thank you for your response...
I found a webpage using that equation, but it doesn't explain what the U means
http://www.physics247.com/physics-homework-help/electric-potential-energy.php
I am trying to write "the radius of a coulomb barrier" as a mathematical symbol (one symbol, not an equation).
What is the symbol I should use?
Again, thank you. I know these questions sound dumb, but I really can't find it anywhere on the web. Peace
The correct mathematical notation for the Coulomb Barrier would be "rCB" where "r" represents the radius and "CB" represents the Coulomb Barrier. This notation is commonly used in physics and nuclear science literature. It is important to note that the notation may vary slightly depending on the specific context and equations being used. If you are unsure, it is always best to consult the specific style guide or notation conventions being used in the paper you are editing.
FAQ: What is the correct math notation for the Coulomb Barrier?
What is the Coulomb Barrier?
The Coulomb Barrier is a representation of the potential energy barrier that two charged particles experience when they are close to each other. It is a concept used in nuclear physics and is defined as the minimum energy required for two positively charged particles to overcome their mutual repulsion and fuse together.
What is the correct mathematical notation for the Coulomb Barrier?
The Coulomb Barrier is commonly represented by the symbol Vb, where the subscript "b" stands for "barrier". It is also sometimes denoted as VC or VCB.
How is the Coulomb Barrier calculated?
The Coulomb Barrier is calculated using the formula Vb = ke * (Z1 * Z2)/r, where ke is the Coulomb constant, Z1 and Z2 are the charges of the two particles, and r is the distance between them.
Can the Coulomb Barrier be negative?
No, the Coulomb Barrier is always a positive value. This is because it represents the minimum energy required for two particles to overcome their mutual repulsion and fuse together. A negative value would indicate that the particles are already bound and do not require any additional energy to fuse.
How is the Coulomb Barrier related to nuclear reactions?
The Coulomb Barrier plays a crucial role in nuclear reactions as it determines the likelihood of two particles fusing together. If the energy of the particles is lower than the Coulomb Barrier, the reaction is unlikely to occur due to the strong mutual repulsion. However, if the energy is higher than the Coulomb Barrier, the particles can overcome their repulsion and fuse, resulting in a nuclear reaction.
