What is the Correct Method to Determine the Coplanarity of Vectors?
  • MHB
  • Thread starter GreenGoblin
  • Tags
    Vectors
In summary: So if u is perpendicular to both v and w (meaning the determinant is zero), then this just means the three vectors are coplanar.
GreenGoblin
68
(1,-1,a)
(1,2,2a)
(3,-a,9)
are three vectors. We have to find 'a' that makes them coplanar
The strategy suggested to me is that this is done by... choosing two of the vectors and taking a crossproduct, then (IT SHOULDNT MATTER WHICH TWO SINCE THEY DONT REALLY COME IN A SET ORDER) dottying with the third. This should give... ZERO as the outcome, right? If this is the wrong strategy please tell me because I have done the question wrong.
I get 3 and 9 as my values of a as the triple product I make a^2 - 12a + 27. This is a question where I am fine with the calulcations but I can't find any material that says, yes, this is definitely the correct method. Even wikipedia confuses me more. But am I using the right idea? IS my answer ok can someone say? Please?
ALSO NEXT QUESTiON (not related to these same vectors this is general)
show that:
(i) if a.c = b.c for all c, then a = b
(ii) if a x (b x c) = (a x b) x c ,then (a x c) x b = 0
for (i) i haven't a clue because all i see is something obvious that already 'shows' itself. what can you do to show it apart from rearrange but then that is still the same.
for (ii) i am thinking of triple scalar expansion and showing equality but then that doesn't 'show' anything more than the orignal statement does...? does it/
a x (b x c) = (a.c)b - (a.b)c
(a x b) x c = -(c.b)a + (c.a)b
equality implies (a.b)c = (c.b)a
but what to do from there/
take any two vectors find the cross product the resulting vector would be perpendicular to the plane containing these two vectors
then find the dot product of the result of the cross with the remaining vector this should be zero since the dot product of any two perpendicular vectors equal zero
am i correct
GreenGoblin said:
(1,-1,a)
(1,2,2a)
(3,-a,9)
If these are coplanar then the third is a linear combination of the first two.
CB
GreenGoblin said:
(1,-1,a)
(1,2,2a)
(3,-a,9)
Your method and answer are both correct.
show that:
You know that (a–b).c = 0 for all c, therefore in particular when c = a–b ... .
Opalg said:
Your method and answer are both correct.You know that (a–b).c = 0 for all c, therefore in particular when c = a–b ... .
i think i see...
we are considering a counter example, if a =/= b then for the case c= a-b, then (a-b)(a-b) = 0 but, a-b =/= 0 so this is not possible since a nonzero vector dottyed with itself... cannot give 0! (Coffee)
CB
These give us the three equations:
\( \begin{array}{ccccc} \lambda & + & \mu & = & 3 \\ -\lambda&+&2 \mu & = & -a \\ \lambda a&+&2 \mu a & = & 9 \end{array} \)
Adding the first and second gives: \(\mu=1-\frac{a}{3} \),
Substituting into the first gives: \(\lambda =2+\frac{a}{3} \)
then substituting these into the third gives: \(a^2-12 a+27=0 \), so \(a=3\) or \(9\)
The \(a=3\) solution is degenerate (if gives \(\mu=0\) ) and the third vector is a multiple of the first (but they are trivially coplanar), which leaves \( a=9 \) as non-degenerate
CB
GreenGoblin said:
am i correct
yea you are correct 3,9 a values
In fact, the dot product of vector u with the cross product of vectors v and w is simply a determinant:
If u= <a, b, c>, v= <d, e, f>, and w= < g, h, i> then
$$ w \cdot (v\times w)= \left|\begin{array}{ccc}a & b & c \\ d & e & f \\ g & h & i\end{array}\right| $$
so here you want to find a so that
$$ \left|\begin{array}{ccc}1 & -1 & a \\ 1 & 2 & 2a \\ 3 & -a & 9 \end{array}\right|= 0 $$
CB
how relevant is degeneracy? as far as i am aware it has not been covered in my course and i don't thinkis needed for my purpose but thanks for the details. does this make a=3 invalid? degenerate sounds like a pejorative term i am guessing it is not good in other contexts it is not good... but then again callimg someone irrational is not usually good and irational numberrs are fine
in this case "degenerate" means: "not fully general". for example, two lines (in a plane) don't always intersect in a point, because they might be parallel. this is a "degenerate" (special) case. the reason why a = 3 is degenerate, is it makes two of the vectors collinear (namely, (1,-1,3) and (3,-3,9)), so that all 3 vectors cannot help but be co-planar.
often, a "degenerate" case is one where "something" is 0: for example a point is a degenerate circle, because it has 0 radius.
see: http://en.wikipedia.org/wiki/Degeneracy_(mathematics)
ok, so, is it still a valid solution?
In this case degeneracy implies one of the vectors is a multiple of the other, so effectively you have only two vectors, which are trivially coplanar since two vectors define a plane.
CB
yes, it is still a valid solution.
Any two vectors determine two lines through the origin which will then define a single plane. The "generic" case is that a third vector will then give a set that will span three dimensions. The case where the three vectors span only two dimensions or one are "degenerate". Note that if all three vectors span a single line (so any vector of the three is a multiple of one other vector) that line lies in one plan so they still lie in a single plane.
FAQ: What is the Correct Method to Determine the Coplanarity of Vectors?
What does it mean for vectors to be coplanar?
Coplanarity of vectors refers to the property of two or more vectors lying on the same plane. This means that the vectors can be drawn on a flat surface without any of them crossing over each other.
How can you determine if vectors are coplanar?
There are a few methods to determine coplanarity of vectors. One way is to check if the vectors lie on the same plane when drawn on a graph or coordinate system. Another way is to calculate the cross product of the vectors and see if it equals to zero. If it does, then the vectors are coplanar.
What are some real-life applications of coplanarity of vectors?
Coplanarity of vectors is used in various fields such as physics, engineering, and navigation. For example, in engineering, it is used to determine the forces acting on a structure and their directions. In navigation, it is used to determine the direction and magnitude of a plane's velocity.
Can more than three vectors be coplanar?
Yes, any number of vectors can be coplanar as long as they lie on the same plane. This includes two, three, four, or even more vectors.
What happens if vectors are not coplanar?
If vectors are not coplanar, it means that they do not lie on the same plane. This could happen if one or more of the vectors are not parallel to the others. In this case, the vectors are said to be non-coplanar.
