MHB What is the correct probability for P(3<X<4|X>1)?
The discussion centers on calculating the conditional probability P(3<X<4|X>1) for a continuous random variable X with a given density function. The user initially calculated the normalization constant C as 2/27 and derived a final probability of 9/32. However, a participant pointed out that the denominator for P(X>1) was incorrectly computed, leading to confusion. The correct interpretation shows that P(X>1) equals 1, making the results of 9/32 and 9/27 equivalent, despite the book's presentation. The conversation highlights the importance of careful probability calculations and understanding the implications of the density function.
Yankel
Hello, I have this question, which I think I solve correctly, but I am getting the wrong answer.
X represent the point that the computer chooses on a scale of 2 to 5 (continuous scale) in a non-uniform way using the density:
f(x)=C*(1+x)
what is the probability P(3<X<4|X>1) ?
I solved the integral from 2 to 5 to find that C=2/27
Then using this value I did conditional probability P(3<X<4)/P(X>1). The nominator was 1/3 and the denominator was 32/27, my final result is then 9/32. The answer I have with the question is 9/27. Which one is wrong then ? Can you assist me please? Thank you in advance !
I have
$$\displaystyle c\times \int_2^5 x+1 ~dx = 1$$
$$\displaystyle c\times \left[ \frac{x^2}{2}+x\right]_2^5 = 1$$
$$\displaystyle c\times \left(\left[ \frac{5^2}{2}+5\right]-\left[ \frac{2^2}{2}+2\right]\right) = 1$$
$$\displaystyle c\times \left(\left[ 12.5+5\right]-\left[ 2+2\right]\right) = 1$$
$$\displaystyle c\times \left(\left[ 17.5\right]-\left[ 4\right]\right) = 1$$
$$\displaystyle c = \frac{1}{13.5} = \frac{2}{27}$$
f(x)=C*(1+x)
Hi Yankel,
I got the same thing for $C$ and the same numerator since $P([3<X<4] \cap [X>1])=P(3<X<4)$. For the denominator though it seems like you used this integral:
$$ \frac{2}{27} \int_{1}^{5} (1+x) \, dx = \frac{32}{27}$$
Remember though that any probability must be between 0 and 1, so this isn't a valid answer. The small mistake comes from the fact that $P(X<2)=0$ and $P(X>5)=0$, so $P(X>1)=P(2<X<5)=1$. For some reason the book chose to write the answer as 9/27 instead of 1/3, but those are equivalent answers. :)
Oh...how did I miss this...typing numbers without thinking (Doh)
thanks !
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
