What is the correct range of tau for case (4) in the Convolution 2 picture?
  • MHB
  • Thread starter aruwin
  • Tags
    Convolution
In summary, the range of tau for case (4) is from 0 to T/2 when t < T/2, and from T/2 to T when t > T/2. This is because the time delay, tau, is the time difference between when the wave starts and when it reaches its maximum amplitude. This depends on the value of t, which can either be less than or greater than T/2.
aruwin
208
Hi! Can someone show me how to get the range of tau for case (4) in the picture? Because when I draw it, the overlapped range I get is from t-T/2 to T, but in the solution, it says t-T to T/2.
Sure, I'd be happy to help! Let's first define the variables in case (4) for reference:
- t = starting time
- T = period of the wave
- tau = time delay
To determine the range of tau for case (4), we need to consider the following conditions:
- The wave starts at time t and ends at time t+T
- The time delay, tau, is the time difference between when the wave starts and when it reaches its maximum amplitude
Based on these conditions, we can see that the range of tau can vary depending on the value of t. Let's break it down into two cases:
Case 1: When t < T/2
In this case, the wave starts at time t and ends at time t+T. The time delay, tau, is the time difference between when the wave starts (t) and when it reaches its maximum amplitude (t+tau). Since the maximum amplitude occurs at t+T/2, the time delay would be T/2. Therefore, the range of tau would be from 0 to T/2.
Case 2: When t > T/2
In this case, the wave starts at time t and ends at time t+T. However, the maximum amplitude occurs at t-T/2. This means that the time delay, tau, is the time difference between when the wave starts (t) and when it reaches its maximum amplitude (t-T/2). Therefore, the range of tau would be from T/2 to T.
In conclusion, the range of tau for case (4) is from 0 to T/2 when t < T/2, and from T/2 to T when t > T/2. I hope this helps clarify any confusion! Let me know if you have any further questions.
FAQ: What is the correct range of tau for case (4) in the Convolution 2 picture?
What is tau?
Tau is a mathematical constant that is equal to 2*pi, where pi is approximately 3.14. It is often used in scientific calculations, especially in fields such as physics and engineering.
What is case (4) in the Convolution 2 picture?
Case (4) in the Convolution 2 picture refers to a specific scenario or situation where the mathematical concept of convolution is applied. This case specifically involves the convolution of two functions, one of which is a shifted or delayed version of the other.
The correct range of tau for case (4) in the Convolution 2 picture is any real number, as long as it is within the limits of the given functions being convolved. However, for practical purposes, it is often limited to the positive real numbers.
Why is tau important in case (4) of Convolution 2?
Tau is important in case (4) of Convolution 2 because it represents the time delay between the two functions being convolved. This time delay can greatly affect the resulting convolution and is therefore an important factor to consider in the calculation.
How is tau calculated for case (4) of Convolution 2?
Tau is typically calculated as the difference between the time values of the two functions being convolved. In case (4) of Convolution 2, one function is usually shifted or delayed by a certain amount, and this amount is used as the value of tau in the calculation.
