What Is the Correct U-Substitution for This Integral?
  • MHB
  • Thread starter karush
In summary, the integral $I=\int \frac{\sqrt{1-x^2}}{x} \,dx$ can be solved using the trigonometric substitution $x=\sin\theta$, resulting in the solution $I=\ln\left(\frac{\sqrt{1-x^2}+1}{|x|}\right)+C$. This method is equivalent to using the "standard" integral $\int \frac{1}{\sin\theta} \,d\theta=-\ln\left(\cot\theta+\csc\theta\right)+C$.
karush
MHB
3,269
$\large{67}$
$$\displaystyle
I=\int \frac{\sqrt{1-x^2 }}{x} \,dx
= \ln\left({\frac{\sqrt{1-x^2 }}{\left| x \right|}}\right)
+\sqrt{1-{x}^{2}}+C$$
From a triangle this looks like a $\tan\left({\theta}\right)$ Integral
So wasn't sure what the u substitution should be
The answer was from TI-Inspire cx cas
Rewrite:
$$\int\dfrac{\sqrt{1-x^2}}{x}\,dx=\int\dfrac{1-x^2}{x\sqrt{1-x^2}}\,dx$$
Bust 'em up:
$$\int\dfrac{1}{x\sqrt{1-x^2}}\,dx-\int\dfrac{x}{\sqrt{1-x^2}}\,dx$$
The one on the left: use $x=\sin\theta$
The one on the right is equivalent to $\sqrt{1-x^2}+C$
Can you proceed?
$$\displaystyle I=\int\dfrac{\sqrt{1-x^2}}{x}\,dx=\int\dfrac{1-x^2}{x\sqrt{1-x^2}}\,dx
=\int\dfrac{1}{x\sqrt{1-x^2}}\,dx-\int\dfrac{x}{\sqrt{1-x^2}}\,dx$$
solving
$$\displaystyle
\int\dfrac{1}{x\sqrt{1-x^2}}\,dx \\
x=\sin\theta \ \ \ \ dx=\cos\left({\theta}\right) \, d\theta \\
\int \frac{\cos\left({\theta}\right)}{\sin\left({\theta}\right)\cos\left({\theta}\right)} \, d\theta
= \int \frac{1}{\sin\left({\theta}\right)} \, d\theta
= \ln\left({\frac{\left| \sin\left({\theta}\right) \right|}{\cos\left({\theta}\right)+1}}\right)
doing something ?
It's a "standard" integral:
$$\int\dfrac{1}{\sin\theta}\,d\theta=\int\csc\theta\,d\theta=-\ln|\cot\theta+\csc\theta|+C=-\ln\left(\dfrac{\sqrt{1-x^2}+1}{|x|}\right)+C$$
TI gave something else... oh well
FAQ: What Is the Correct U-Substitution for This Integral?
What is the purpose of the "UHWO 242 int sqrt(1 - x^2 ) /x" equation?
The purpose of the "UHWO 242 int sqrt(1 - x^2 ) /x" equation is to calculate the definite integral of the square root of 1 minus x squared, divided by x.
How is this equation used in scientific research?
This equation is commonly used in physics and engineering research to calculate the area under a curve in a specific interval. It can also be used to model various phenomena, such as the motion of a pendulum or the shape of a satellite's orbit.
What is the significance of the "UHWO 242" in the equation?
The "UHWO 242" is simply a label or identifier for this specific equation. It may be used in a particular course or research project to differentiate it from other equations.
Can this equation be applied to real-life situations?
Yes, this equation can be applied to real-life situations as it is commonly used in various fields of science and engineering to solve problems and make predictions.
Are there any limitations to using this equation?
Like any mathematical equation, there are limitations to using this equation. It may not be applicable to all situations and may require certain assumptions or conditions to be valid.
