MHB What is the Correct Value of r if 9!/(9-r)! = 840?
  • Thread starter Thread starter mathdad
The equation 9!/(9 - r)! = 840 was analyzed to find the correct value of r. Initially, r was thought to be 4, but upon recalculating, it was determined that 9!/(5!) equals 3024, not 840. Consequently, there is no integer solution for r within the range of 0 to 9 that satisfies the equation. The discussion highlights the importance of careful calculation in solving factorial equations. Ultimately, the conclusion is that the equation has no valid solution.
mathdad
9!/(9 - r)! = 840
I found r to be 4.
Is this correct?
Mathematics news on Phys.org
RTCNTC said:
9!/(9 - r)! = 840
I found r to be 4.
Is this correct?
$\dfrac{9!}{(9-4)!} = \dfrac{9!}{5!} = 9 \cdot 8 \cdot 7 \cdot 6 = 3024$
there is no solution to the equation $\dfrac{9!}{(9-r)!} = 840$ for $0 \le r \le 9 \, , \, r \in \mathbb{Z}$
I messed up in my calculation. Thanks.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
