MHB What Is the Correct Volume of the Region Revolving Around x=1?
  • Thread starter Thread starter karush
The volume of the region bounded by the curves \(y=\sqrt{x}\), \(y=1\), and the y-axis, when revolved around \(x=1\), can be calculated using both the shell and washer methods. The shell method yields a volume of \(\frac{7\pi}{15}\) through the integral \(V=2\pi\int_0^1 (1-x)(1-x^{\frac{1}{2}})\,dx\). Similarly, the washer method confirms this volume with the integral \(V=\pi\int_0^1 1^2-(1-y^2)^2\,dy\). Both methods provide consistent results, resolving discrepancies with the book's answer of \(\frac{8\pi}{15}\). The discussion highlights the effectiveness of both methods in calculating the volume accurately.
karush
MHB
Find the volume of a region bounded by $y=\sqrt{x}$, $y=1$ and the $y-axis$ that revoles around $x=1$
$$x_1=y^2$$
$$\int_{0}^{1} \left(x_1-1\right)^2\,dy =\frac{8\pi}{15}$$
Book answer is $$\frac{7\pi}{15}$$ ?
If we choose the shell method here, with:
$$dV=2\pi rh\,dx$$
$$r=1-x$$
$$h=1-y=1-x^{\frac{1}{2}}$$
And so, we have:
$$V=2\pi\int_0^1 (1-x)\left(1-x^{\frac{1}{2}}\right)\,dx=2\pi\int_0^1 1-x^{\frac{1}{2}}-x+x^{\frac{3}{2}}\,dx=2\pi\left[x-\frac{2}{3}x^{\frac{3}{2}}-\frac{1}{2}x^2+\frac{2}{5}x^{\frac{5}{2}}\right]_0^1=2\pi\left(1-\frac{2}{3}-\frac{1}{2}+\frac{2}{5}\right)=\frac{\pi}{15}\left(30-20-15+12\right)=\frac{7\pi}{15}$$
If we choose the washer method instead, we then have:
$$dV=\pi\left(R^2-r^2\right)\,dy$$
$$R=1$$
$$r=1-x=1-y^2$$
And so we have:
$$V=\pi\int_0^1 1^2-(1-y^2)^2\,dy=\pi\int_0^1 2y^2-y^4\,dy=\pi\left[\frac{2}{3}y^3-\frac{1}{5}y^5\right]_0^1=\pi\left(\frac{2}{3}-\frac{1}{5}\right)=\frac{\pi}{15}(10-3)=\frac{7\pi}{15}$$
Thanks just wasn't a good example in the book
So that really helps a lot mahalo
We could also use the disc (washer) method.
$$\pi(\int_0^1dy-\int_0^1(1-y^2)^2dy)=\pi(1-\int_0^1(y^4-2y^2+1)\,dy)=\pi(1-[\frac{1}{5}y^5-\frac{2}{3}y^3+y\Big|_0^1)=\pi(1-\frac{1}{5}+\frac{2}{3}-1)=\pi(\frac{2}{3}-\frac{1}{5})$$
$$\pi(\frac{2}{3}-\frac{1}{5})=\frac{7\pi}{15}$$
- - - Updated - - -
$$R=1$$
$$r=1-x=1-y^2$$
And so we have:
But I see that Mark has already posted the correct washer method.
