What is the Correct Way to Calculate the Area of a Triangle?
In summary: Looks like the math teacher that made that up "eyed" 50 and 30 !In summary, In summary, the area of \triangle ABC is 1600cm^2.
Yazan975
30
Mathematics news on Phys.org
Let's go through this step by step...can you find the area of \(\displaystyle \triangle ABC\) ?
3200cm^2
Yazan975 said:
3200cm^2
That's not correct...how did you arrive at that answer?
1600cm^2?
For 3200 I multiplied Base and Height but didn't divide by 2
Yazan975 said:
1600cm^2?
Okay, good...so what must the area of \(\displaystyle \triangle AED\) be?
xy/2 cm^2
Yazan975 said:
xy/2 cm^2
Yes, that's correct in terms of \(x\) and \(y\), but we should also be able to assign a numeric value to its area based on the fact that the areas of the two shaded regions are the same. (Thinking)
This will give us an equation...can you state it?
xy/2 cm^2 = 800
xy = 1600
Is that right?
Yazan975 said:
xy/2 cm^2 = 800
xy = 1600
Is that right?
Excellent! (Yes)
Okay, now the next thing I notice is that within \(\displaystyle \triangle ABC\) there are two similar triangles, with \(\displaystyle \triangle AED\) being the smaller of the two. This means we may state:
\(\displaystyle \frac{y}{x}=\frac{40}{x+10}\)
Do you see where this comes from?
What I would do here is solve both equations we now have for \(y\), and equate the two results to get an equation in \(x\)...can you state this equation?
MarkFL said:
Excellent! (Yes)
I see where it comes from but problem is I got stuck at 40x = 1600+10y
I couldn't get an equation in terms of x
- - - Updated - - -
- - - Updated - - -
I would solve the second equation for \(y\) to obtain:
\(\displaystyle y=\frac{40x}{x+10}\)
And solving our first equation for \(y\) we have:
\(\displaystyle y=\frac{1600}{x}\)
Hence:
\(\displaystyle \frac{40x}{x+10}=\frac{1600}{x}\)
This results in a quadratic in \(x\)...can you write the equation in standard quadratic form?
Yeah, here's the formula:
x^2-40x-400=0(after dividing the equation by 40)
Hence, x=20??
Thing is my answer sheet says y= 30 and x=50
Yes, that equation is correct.
Yazan975 said:
Hence, x=20??
I would use the quadratic formula to solve the equation, and you'll find a different value for \(x\), after discarding the negative root. Can you find this value?
I don't see how \(x\) and \(y\) can differ by 20 though, and the values for \(x\) and \(y\) given by your answer sheet cannot be correct.
Agree. Anyhow, the difference between x and y is not required as a given.
FAQ: What is the Correct Way to Calculate the Area of a Triangle?
How do I use the Area of Triangle Calculator?
To use the Area of Triangle Calculator, simply enter the length of the base and the height of the triangle into the designated fields. Then, click on the "Calculate" button to get the area of the triangle.
Can I use this calculator for any type of triangle?
Yes, this calculator can be used for any type of triangle as long as you enter the correct values for the base and height. It will provide the area for all types of triangles, including equilateral, scalene, and isosceles triangles.
How accurate is the Area of Triangle Calculator?
The calculator provides accurate results up to the decimal point. However, the accuracy also depends on the accuracy of the values entered for the base and height of the triangle.
Is this calculator free to use?
Yes, this calculator is completely free to use. There are no hidden fees or charges for using it.
Can I use this calculator on my mobile device?
Yes, this calculator is accessible on all types of devices, including desktops, laptops, tablets, and mobile phones. It is a user-friendly and responsive calculator that can be used on any device with an internet connection.
