What is the Coulomb's Law formula for calculating point charges?
In summary, the conversation discusses the calculation of point charges based on their attraction and distance. The equation q1-q2= 6 *106 is used to find the relevant equation for q2, and the Coulomb's law formula F=q1*q2/4 *3.14*epsilon0 *r2 is mentioned. There is a question about whether to use - q1q2 or simply q1*q2 in the formula. The response suggests that there is no difference in the magnitude of the result and advises against unnecessary simplifications.
logearav
338
The sum of two point charges is 6 micro coulomb. They attract each other with a force of 0.9 Newton, when kept 0.4 m apart in vacuum. calculate the charges.
since it is attractive force, i formed the equation q1-q2= 6 *106 and got the relevant equation for q2
then we have the coulomb's law f = q1*q2/4 *3.14*epsilon0 *r2
Should i use - q1q2 or simply q1*q2 in the coulomb's formula
hi logearav! :smile:
what difference does it make? … the magnitude of the result will be the same anyway :confused:
(btw, i assume you used q1 - q2 (instead of q1 + q2) because you were trying to simplify things …
not much point in simplifications if they confuse you later! :rolleyes:)
Thanks a lot tiny-tim.
FAQ: What is the Coulomb's Law formula for calculating point charges?
What is electrostatics?
Electrostatics is the branch of physics that deals with the study of electric charges at rest. It involves the study of the behavior of stationary electric charges, electric fields, and their interaction with each other.
What is an electrostatics problem?
An electrostatics problem is a physics question or scenario that involves the study of electric charges at rest and their behavior. These problems often require the use of equations and principles from electrostatics to find a solution or answer.
What are some common types of electrostatics problems?
Some common types of electrostatics problems include calculating the electric field or potential at a certain point, finding the force between two electric charges, and analyzing the behavior of charged particles in an electric field.
What are the main principles used to solve electrostatics problems?
The main principles used to solve electrostatics problems are Coulomb's Law, Gauss's Law, and the principle of superposition. Coulomb's Law describes the force between two electric charges, Gauss's Law relates the electric field to the charge enclosed by a surface, and the principle of superposition states that the total electric field at a point is the sum of the electric fields from individual charges.
How can I approach solving an electrostatics problem?
To solve an electrostatics problem, it is important to first understand the given scenario and identify the known and unknown variables. Then, apply the relevant principles and equations to set up an appropriate equation or system of equations. Finally, solve for the unknown variable(s) and check your answer for reasonableness.
9K
