What is the decimal part of the sixth power of the sum of two square roots?
  • MHB
  • Thread starter anemone
  • Tags
    2016
In summary, the purpose of finding the decimal part of the sixth power of the sum of two square roots is to obtain a more precise and accurate value for the overall result. To calculate the decimal part, you would first find the square roots of the two numbers, then add them together and raise the sum to the sixth power, and finally subtract the whole number part to get the decimal part. The decimal part can be negative if the result of the calculation is negative. The sixth power is used to increase the precision and accuracy of the result. This calculation has real-world applications in various fields such as engineering, physics, finance, and computer programming.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Given that the decimal part of $X=\left(\sqrt{13}+\sqrt{11}\right)^6$ is $Y$, find the value of $X(1-Y)$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution::)
1. kaliprasad
2. Opalg
Solution from kaliprasad:
Let us take $Z = (\sqrt{13} - \sqrt{11})^6$
Now $ (\sqrt{13} - \sqrt{11}) < 1$ so $ Z < 1$
$\begin{align*}X+Z &= (\sqrt{13} + \sqrt{11})^6 + (\sqrt{13} - \sqrt{11})^6
\\&= 2((\sqrt{13})^ 6 + {6 \choose 2} (\sqrt{13})^4 (\sqrt{11})^2 + {6 \choose 4} (\sqrt{13})^2 (\sqrt{11})^4 + (\sqrt{11})^6)\\&= 2( 13^ 3 + {6 \choose 2} 13^4 * 11 ^2 + {6 \choose 4} 13^2 * 11 ^4 + 11^3)\,\,\text{which is an integer}\end{align*}$
As $Z < 1$ and $Y$ is decimal part of $X$ and $X+Z$ is an integer $\therefore Z = 1 - Y$ and
$\begin{align*}X(1-Y) &= XZ \\&= (\sqrt{13} + \sqrt{11})^6 * (\sqrt{13} - \sqrt{11})^6 \\&= (13-11)^6\\& = 2^6 \\&= 64\end{align*}$
Alternate solution from Opalg:
My little pocket calculator gives $\bigl(\sqrt{13} + \sqrt{11}\bigr)^6 = 110016$ (to 8 significant figures). So we can expect $X$ to be very close to an integer. This means that its fractional part $Y$ will be either very small or very close to $1$.
Square it first, to get $\bigl(\sqrt{13} + \sqrt{11}\bigr)^2 = 24 + 2\sqrt{143} = 2\bigl(12 + \sqrt{143}\bigr).$ Then cube that, getting $$X = \bigl(\sqrt{13} + \sqrt{11}\bigr)^6 = 8\bigl(1728 + 432\sqrt{143} + 5148 + 143\sqrt{143}\bigr) = 8\bigl(6876 + 575\sqrt{143}\bigr).$$ Write that as $X - 8\times6876 = 8\times575\sqrt{143}$, and square again: $$X^2 - 110016X + 64\times6876^2 = 64\times575^2\times143$$ (notice that the number $110016$ has made an appearance here!). Therefore $$X(110016-X) = 64(6876^2 - 143\times575^2).$$ A bit more arithmetic using the pocket calculator comes up with the pleasing result that $6876^2 - 143\times575^2 = 1.$ (For a deeper explanation of why this is so, notice that $\dfrac{6876}{575}$ is one of the convergents for the http://personal.maths.surrey.ac.uk/ext/R.Knott/Fibonacci/cfCALC.html of $\sqrt{143}$).
Therefore $X(110016-X) = 64$. Since we know that $X\approx 110016$, it follows that $110016 - X \approx \dfrac{64}{110016} \approx 0.0005817336$. This confirms that $X$ is indeed very slightly less than $110016$, its integer part being $110015$ and its fractional part $Y$ given by $1-Y = 110016 - X$, so that $Y \approx 1 - 0.0005817336 = 0.9994182664.$
Finally, $X(1-Y) = 64$.
Notice that, just by using the little pocket calculator, we get the result $X = 110015.9994182664$ correct to 16 significant digits.
FAQ: What is the decimal part of the sixth power of the sum of two square roots?
What is the purpose of finding the decimal part of the sixth power of the sum of two square roots?
The purpose of this calculation is to obtain a more precise and accurate value for the overall result, as the decimal part can provide more information than just the whole number. This can be helpful in various scientific and mathematical applications.
How do you calculate the decimal part of the sixth power of the sum of two square roots?
To calculate the decimal part, you would first find the square roots of the two numbers. Then, add the two square roots together and raise the sum to the sixth power. Finally, subtract the whole number part of the result to obtain the decimal part.
Can the decimal part of the sixth power of the sum of two square roots be negative?
Yes, the decimal part can be negative if the result of the calculation is a negative number. This can happen if the sum of the square roots is a negative number or if the sixth power of the sum is a negative number.
What is the significance of the sixth power in this calculation?
The sixth power is used in this calculation to increase the precision and accuracy of the result. Raising the sum of the square roots to the sixth power is a more complex operation than just taking the square root or squaring the number, which can help in obtaining a more precise and detailed value.
Is there any real-world application for finding the decimal part of the sixth power of the sum of two square roots?
Yes, this calculation can be used in various scientific and mathematical fields, such as in engineering, physics, and finance. It can also be applied in computer programming and data analysis to obtain more accurate results and make more informed decisions.
