What is the definite integral of 1/(36+x^2) with bounds [0, 6]
The definite integral of 1/(36+x^2) from 0 to 6 can be solved using the formula for the integral of 1/(a^2 + u^2), which results in (1/a)tan^-1(u/a) + C. By letting u = x/6, the integral simplifies to (1/6)arctan(x/6). Evaluating this from 0 to 6 gives (1/6)(π/4) - 0, which equals π/24. This method avoids the need for a calculator and confirms the answer is π/24.
Chandasouk
What is the definite integral of 1/(36+x^2) with bounds [0, 6]?
I've only been taught U substitution to handle problems like these. I let u = 36+x^2 and du=2xdx but I am stuck and don't know what to do. Te answer is pi/24 but I don't know how to obtain it.
Is there a better u to choose? if so, what?
Hint: What is \frac{d}{du}\tan^{-1}(u)?
U substitution isn't needed. Look at an integration table.
Hint: The function being integrated takes the shape of 1/(x2+a2)
Okay, I used that formula u gave me although in my book it is written as
du/a^2+u^2 = 1/a*tan^-1(u/a)+C
But I had to evaluate it with a calculator [0, 6]
1/6*tan^-1(1)-1/6*tan^-1(0) = 0.1308 which is about pi/24
How would I solve it without a calculator?
Well, 1/6*tan^-1(1)-1/6*tan^-1(0)=1/6*tan^-1(1)-0=1/6*tan^-1(1). So I guess you would need to know that tan^-1(1)=\pi/4.
Keep in mind that u=\tan^{-1}(x) means that \tan(u)=\frac{\sin(u)}{\cos(u)}=x...so where does \frac{\sin(u)}{\cos(u)} equal zero? Where does it equal one?
factor out a 36 in the denominator and in the denominator you'll get: 36(1+(x/6)^2)
let u = x/6 and when you take the derivative and substitute in the original, you should get:
(1/6)[1/(1 + u^2)] and integrate, remembering that 1/(1 + u^2) is tan^-1 u after you integrate, then you can go from there.
answer after you integrate is (1/6)arctan(x/6) + C..
then just evaluate it for 0 to 6
(1/6)arctan(6/6)-[(1/6)arctan(0/6)]
[(1/6)*(Pi/4)]-0= Pi/24
  • · Replies 105 ·
  • · Replies 16 ·
  • · Replies 19 ·
