What is the definition of 1 meter?
In summary: E6 meters So, it would be nice to reduce all constants to 1E1 (and get rid of units).Yes, it would be very helpful to have a system of units where all constants are reduced to 1. This would make things a lot easier to remember and would attract more females to physics courses.
KLscilevothma
322
What is the defination of 1 meter? My physics teacher told me it's related to the frequency of a certain EM wave, but he couldn't remember the whole story. Perhaps it also explains why the speed of light is 299792458 m/s, which is an integer.
The original physical definition of a meter
was not quite precise. Then it became the
steel metal bar that is currently kept
in a vacuum safe in the International
Standards Institute (I think that's its name)
in Paris. I don't know if it was converted
into an EM frequency definition (if we have
an exact metric definition of c), but of
course you can find the ("almost" at least)
accurate value by [nu] = c / [lamb] <Hz> with
[lamb] = 1 m .
Live long and prosper.
Hi KL,
The "meter" is the length of a sterling silver bar (at some given temperature) on display somewhere in England (I think). Supposedly the geodic reference is 10^-7 of the distance from the north pole to the equator of the Earth.
BTW: If an integral value of "c" were really desired why not alter the length of the meter such that the velocity of light would be exactly 3. E +8 neo-meters/second? Cheers, Jim
England ?! I'm pretty certain it's Paris and
the kilogram is there too, I think (the
English mesauring units are feet and inches.)
I don't remember about the material and
temp. parts (I still believe it's vaccum).
Supposedly the geodic reference is 10^-8 of
What are you talking about ?!
Hmm... tradition maybe ? :wink:
I think, old meter standard was x-shaped (in cross section) Pt-Ir alloy bar with two scratches on it, kept somewhere in Paris (not in a vacuum, because Pt and Ir are quite stable against elements, and because from time to time people come with their meter stcks to check against prime one).
Currently I believe a standard of length is dead.
New standard is instead a standard of time (to be exact, of frequency), and a meter is simply calculated using speed of light: l =ct=c/f.
New standard is instead a standard of time (to be exact, of frequency), and a meter is simply calculated using speed of light: l =ct=c/f. [/B]
Yes, the current standard makes use of the constancy of speed of light in vacuum for all observers, plus a standard for time (which makes sense given the achievable accuracy for time measurements). It defines the meter as the distance covered by a light beam in 1/299792458 of a second. That is why the value of c is now exactly 299792458 m/s.
As Drag suggested, meter shall be simplified to have speed of light exactly 3E8 m/s Very good idea.
Shall we block NIST entrances, or just strike at our business locations?
It would also be nice to reduce all constants to 1E1 (and get rid of units).
I suggested that ?
Sorry, my mistake, Neo suggested that indeed.
But I really think it is a cool idea - to simplify those hard to memorise trains of numbers.
I think in QED and GR books they are already close to that (they routinely use h=G=c=1 system).
I wonder if phys 101-201 texts will look easier (and attracts more females) with such system?
Originally posted by drag
I suggested that ?
Hi Drag,
Here's what Feynman - Leighton - Sands Vol I page 5-10 says:
"It might be thought that it would be a good idea to use some natural length as our unit of length -- say the radius of the Earth or some fraction of it. The meter was originally intended to be such a unit and was defined to be ([pi]/2) X 10^-7 times the Earth's radius. - -
For a long time it has been agreed internationally that the meter would be defined as the distamce between two scratches on a bar kept in a special laboratory in France. It is currently being considered that a new definition be adopted, an agreed upon (arbitrary) number of wave lengths of a chosen spectral line."
My original post had a mistake (recently edited) that had stated that there were 10,000 kilometers between the north pole and the equator A quick calc. using Feynman's formula and assuming that the Earth's circumference is 25,000 miles and each mile contains 1.6 kilometers, gives that same number as the distance between the north pole and the equator.
I didn't know Leighton but I knew Dick Feynman in Feb, 1945 and Matt Sands was my "Differential Equations" Prof in 1946 at Univ of Los Alamos, NM. Cheers, Jim
NIST has some information about this topic.
FAQ: What is the definition of 1 meter?
The definition of 1 meter is a unit of length in the International System of Units (SI) equal to 100 centimeters or approximately 39.37 inches.
How was the definition of 1 meter established?
The definition of 1 meter was established in 1791 by the French Academy of Sciences, which defined it as one ten-millionth of the distance from the equator to the North Pole along a meridian passing through Paris.
What are some common uses for the 1 meter measurement?
The 1 meter measurement is commonly used in everyday life for measuring the length of objects, such as furniture, vehicles, and tools. It is also used in scientific fields, such as physics and engineering, for more precise measurements.
How does the definition of 1 meter relate to other units of length?
The definition of 1 meter is closely related to other units of length in the SI system, such as the centimeter, decimeter, and kilometer. For example, 1 meter is equal to 100 centimeters, 10 decimeters, and 0.001 kilometers.
Why is the definition of 1 meter considered a fundamental unit of measurement?
The definition of 1 meter is considered a fundamental unit of measurement because it is used as a base unit for other units of length in the SI system. It is also used as a reference for measuring other physical quantities, such as velocity and acceleration.
