What is the definition of wave speed?
  • Thread starter ShudyShab
  • Tags
    Speed Wave
In summary, the speed of a wave can be defined as the rate at which energy is transferred by a progressive wave. However, for a standing wave, the speed is zero because the peaks do not travel, but it has a non-zero frequency. There are also different ways to measure speed for different types of waves, such as phase velocity and group velocity. In non-scientific usage, speed may refer to the frequency of the wave. Additionally, the speed of a stationary wave can be defined as the speed of either the incident or reflected wave, as shown in the CIE marking scheme.
ShudyShab
Hi :) I just want to know how you would simply define the speed of a wave in words?
Because I often get questions asking to define the speed of a standing wave etc.
One of the definitions I know for progressive wave is the rate at which energy is transferred by a wave.
but what about the speed of a standing wave?
Speed can mean different things.
1. The speed of a simple sine wave is the distance that each peak of the sine curve shape travels in a given amount of time (phase velocity).
2. The speed of a wave packet is the distance that the peak of the wave packet's envelope curve travels in a given amount of time (group velocity). Energy travels at the group velocity.
3. In non-scientific usage, "speed" may also refer to the rate in time at which a fixed point in space waves on and off. In science, we call this the "frequency" of the wave, not the "speed".
So, a standing wave has a speed of zero, because the peaks do not travel, but has a non-zero frequency, because points are still waving on or off (or up or down for transverse waves). Take a look at my http://faculty.uml.edu/cbaird/95.658%282011%29/Lecture3.pdf" for a more rigorous explanation.
Thank you :) I'll check out all the links
can't we define the speed of stationary wave as follows:-
Stationary wave is produced by the superposition of incident and reflected waves and the speed of stationary wave is the speed of anyone of the incident or reflected wav.
(As given in marking scheme of CIE).
Thanx that's perfect! Its exactly what I need as I am writing CIE
FAQ: What is the definition of wave speed?
What is the definition of the speed of a wave?
The speed of a wave is the rate at which a wave travels through a medium. It is a measure of how fast the disturbance of the wave is propagated.
How is the speed of a wave calculated?
The speed of a wave can be calculated by dividing the wavelength by the period of the wave. Alternatively, it can also be calculated by multiplying the frequency of the wave by its wavelength.
What factors affect the speed of a wave?
The speed of a wave is affected by the properties of the medium it is traveling through, such as density, elasticity, and temperature. It is also influenced by the frequency and wavelength of the wave.
Is the speed of a wave constant?
No, the speed of a wave is not constant and can vary depending on the properties of the medium it is traveling through. For example, sound waves travel faster in denser mediums, while light waves travel faster in less dense mediums.
Why is the speed of a wave important?
The speed of a wave is important because it determines how quickly information or energy can be transmitted through a medium. It also plays a significant role in the behavior and properties of different types of waves, such as sound and electromagnetic waves.
