Undergrad What is the density of hydrogen atoms in the Universe?
The discussion focuses on calculating the density of hydrogen atoms in the universe, emphasizing the importance of using correct units and constants. The critical density is calculated using the formula ρc = 3H²/8πG, leading to a baryon mass ratio and ultimately the current density of hydrogen atoms, estimated at 2.4244 x 10^18 per m³. It highlights the significant variability in density across different cosmic structures, such as stars and voids, which complicates comparisons with the interstellar medium's density. Participants express appreciation for clarifications on the calculations and acknowledge misconceptions about average density variability. Understanding these factors is crucial for accurate astrophysical assessments.
Buzz Bloom
TL;DR
I calculated a value of the average density in our universe of H atom equivalents per cm^3 based on values of cosmological variables from various sources: 2.4244x10^18 . A Wikipedia value for such a value in the interstellar media is very very much less: 10^6.
I am hoping a PFs participant can find my error or an explanation.
UNITS
m is meters​
kg is kiliograms​
K is degrees Kelvin​
s is seconds​
J is joules​
u is daltons = 1.66053906660(50)×10−27 kg​
1 pc = 3.085678 x 1016 m​
CONSTANTS
MH = mass of hydrogen atom = 1.007825 u​
= 1.673532784796145 ×10−27 kg​
G = gravitational constant = 6.6743 ×10−11 m3⋅/kg⋅s2
VARIABLES
H0 = 70 (km/s)/Mpc​
(This reference has an array of values for H0, each with an error range. The value 70 was calculated as a weighted average using the inverse of the square of the error ranges as multipliers.)​
1/H0 = 4.408 x 1017 s​
DENSITY CALCULATION
Ωm = 0.315 (total mass ratio to critical mass))​
Ωb = 0.15 x 0.315 = 0.04725 (baryon mass ratio)​
(I apologize for losing the URL from which I found 0.15)​
ρc = critical density = 3H2/8πG​
ρb = Ωb x ρc
= (3/8pi) H02/G = 4.0573 x 10-9 kg/m3
NH = current density of H atom equivalents =ρb / MH
= 2.4244 x 1018 per m3
DENSITY FROM WIKIPEDIA
matter is primarily in molecular form, and reaches number densities of 106 molecules per cm3
Space news on Phys.org
You have per ##m^3##. Wiki has per ##cm^3##. factor is ##10^6##.
Likes Buzz Bloom
You're calculating the average density of hydrogen atoms over the entire universe, which includes the volume occupied by things like stars, planets, white dwarfs, and neutron stars, which can have densities many, many orders of magnitude larger than average, and also includes volumes like the "voids" between galactic superclusters, which can have densities orders of magnitude smaller than average.
You are then comparing this to an estimate of the density of the interstellar medium. You should not expect these two numbers to be the same (even after correcting for the units as @haruspex says).
Likes Buzz Bloom
Hi @mathman and @PeterDonis:
I much appreciate your helpful posts. My faulty intuition, even with mathman's correction, was that the variability of average density is much less than it apparently is.
Regards,
Buzz
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 96 ·
11K
  • · Replies 47 ·
