What is the density of the Carina Nebula?
  • Thread starter Thread starter ozipin
    Density Nebula
The Carina Nebula's density is often misrepresented as a few atoms per cubic meter, which is closer to the average density of the intergalactic medium. In reality, the Carina Nebula, classified as a Giant Molecular Cloud (GMC), has a density that is significantly higher, estimated to be 100 to 1,000 times greater than the average density of the solar vicinity, which is about one atom per cubic centimeter. Scholarly references indicate that the density of interstellar matter varies widely, with the densest regions reaching up to 2 × 10−18 g cm−3. Translating column density to actual density is complex and requires specialized knowledge, making it challenging for those unfamiliar with the concepts. Accurate understanding of the Carina Nebula's density is crucial for astrophysical studies.
ozipin
In a James Webb photo thread, someone posted that the Carina Nebula has a density of a few atoms per cubic meter. This seems off to me, as this is close to the average density of the intergalactic medium of one atom per cubic meter, which is much less than the interstellar medium average density of one atom per cubic centimeter, which is much less than the average density of a planetary nebular (100-10,000 atoms per cubic centimeter). But I can't find any information on the web to help me understand this better.
Astronomy news on Phys.org
I believe the Carina nebula is what is called a Giant Molecular Cloud (GMC). The Wikipedia article says the following: "Whereas the average density in the solar vicinity is one particle per cubic centimetre, the average density of a GMC is a hundred to a thousand times as great." The value of one atom/cubic meter is about the average mass density of the universe as a whole, so is much too low for even the vicinity of the sun, let alone a dense nebula like Carina.
For a more scholarly reference, this paper has the following quote, "By terrestrial standards, the interstellar matter is exceedingly tenuous: in the vicinity of the Sun, its density varies from ∼ 1.5 × 10−26 g cm−3 in the hot medium to ∼ 2 × 10−20 − 2 × 10−18 g cm−3 in the densest molecular regions, with an average of about 2.7 × 10−24 g cm−3 (see next subsections). This mass density, which corresponds to approximately one hydrogen atom per cubic centimeter, is over twenty orders of magnitude smaller than in the Earth’s lower atmosphere."
Ibix said:
which gives column densities
Translating column density to density requires some specialist knowledge, though. I'm not sure it helps the OP by itself.
Sure - the reddit poster translated the column densities into a density range on an assumption that the nebula was about 15ly deep from our perspective.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
How does light maintain enough energy in the visible part of the spectrum for the naked eye to see in the night sky. Also, how did it start of in the visible frequency part of the spectrum. Was it, for example, photons being ejected at that frequency after high energy particle interaction. Or does the light become visible (spectrum) after hitting our atmosphere or space dust or something? EDIT: Actually I just thought. Maybe the EM starts off as very high energy (outside the visible...
