What is the Derivative as a Limit?
In summary, the conversation discusses the concept of finding the derivative as a limit and shows the attempt at a solution using various equations and substitutions. The final result is that the derivative exists and is equal to the function itself.
Karol
1,380
Derivative as a limit:
$$y'=\lim_{\Delta x\rightarrow 0}\frac{f(x+\Delta x)-f(x)}{\Delta x}$$
$$f'(x)=\lim{\Delta x\to 0}\frac{f(x)f(\Delta x)-(1+xg(x))}{\Delta x}=\bigstar$$
$$\left\{ \begin{array}{l} f(\Delta x)=1+\Delta x \cdot g(\Delta x)=1 \\ \Delta x\rightarrow 0 \end{array} \right.$$
$$\bigstar=\lim{\Delta x\to 0}\frac{f(x)\cdot 1-1-xg(x)}{\Delta x}=?$$
I don't understand how you get to the formulas behind the brace, but why didn't you go on with this method and substitute the remaining occurrences of ##f(x)## and ##f(\Delta x)## in the formula with the ##\bigstar##?
$$\bigstar=\lim_{\Delta x\to 0}\frac{1+xg(x)-1-xg(x)}{\Delta x}=\frac{0}{0}$$
No. You need the ##f(\Delta x)## term as well. Where has it gone to? Looks like an explosion took place and threw it out of the way. :fire:
But as i showed the ##~f(\Delta x)=1##:
$$\lim_{\Delta x \to 0} f(\Delta x)=1+\Delta x \cdot g(\Delta x)=1+0\cdot 1=1$$
That is correct, But it is not what we are concerned about. You can't just get the limit of some part of the question and substitute it back. You can however do this.
## \lim_{dx \rightarrow 0} {\frac{f(x)f(dx)}{dx}} + \lim_{dx \rightarrow 0} {\frac{f(x)}{dx}}##
But as you see here it gives none sense. What you need to do is turn the originial equation of the limit
Into something you can get the limit of. As the question noted ## \lim_{x \rightarrow 0} {g(x)} = 1##
Remember, The the derivative as a whole has a limit but if you divide the expression it might not.
Consider not substituting ##f(x)## and see what that takes you.
$$f'(x)=\lim_{\Delta x\to 0}\frac{f(x)f(\Delta x)-f(x)}{\Delta x}=\frac{f(x)[f(\Delta x)-1]}{\Delta x}=\frac{f(x)[1+\Delta x\cdot g(\Delta x)-1]}{\Delta x}=$$
$$=\frac{f(x)\cdot\Delta x\cdot g(\Delta x)}{\Delta x}$$
$$f'(x)=\lim_{\Delta x\to 0}[f(x)g(\Delta x)]=f(x)\cdot 1$$
Likes I like Serena
Excellent so the derivative exists, and it is equal to the function itself
Thank you fresh and Biker
FAQ: What is the Derivative as a Limit?
What is the definition of a derivative?
The derivative of a function is the slope of the tangent line at a specific point on the function's graph. It represents the rate of change of the function at that point.
Why is the derivative important in calculus?
The derivative is important because it helps us understand the behavior of a function at a specific point. It allows us to find the maximum and minimum values of a function, as well as the location of these values. It also helps us solve many real-world problems involving rates of change.
What is the difference between a derivative and an antiderivative?
A derivative is the slope of a function at a specific point, while an antiderivative is the original function from which the derivative was derived. In other words, the derivative tells us how the function is changing, while the antiderivative tells us the original function itself.
How do you find the derivative of a function?
To find the derivative of a function, you can use the derivative rules, such as the power rule, product rule, quotient rule, and chain rule. These rules allow you to find the derivative of more complex functions by breaking them down into simpler functions.
Can the derivative of a function be negative?
Yes, the derivative of a function can be negative. A negative derivative indicates that the function is decreasing at a specific point, while a positive derivative indicates that the function is increasing at that point. The magnitude of the derivative also tells us the steepness of the function's slope at that point.
