What is the derivative of the given function at all points where it exists?
In summary, the conversation discusses finding the derivative of a function involving a piecewise definition and a limit at a specific point. The function is shown to be continuous and differentiable at all points, with the derivative being dependent on the value of a. The conversation also mentions taking cases for different values of a to prove a specific step in the process.
mathmari
MHB
5,049
Hey! :eek:
Let $a\in \mathbb{R}$. Find the derivative of the function $f:\mathbb{R}\rightarrow \mathbb{R}$ $$f(x)=\left\{\begin{matrix}
x^ae^{-\frac{1}{x^2}} & \text{ if } x>0\\
0 & \text{ if } x\leq 0
\end{matrix}\right.$$
in all the points $x\in \mathbb{R}$, where it exists. So, first we have to show if and the function is continuous, right? (Wondering)
For $x>0$ and $x<0$ the function is continuous, so we have to check at $x=0$.
$\lim_{x\rightarrow 0^+}f(x)=\lim_{x\rightarrow 0^+}x^ae^{-\frac{1}{x^2}}=0$, for each $a$, or not?
$\lim_{x\rightarrow 0^-}f(x)=0$.
$f(0)=0$
So, the function is continuous at $x=0$.
Then for $x>0$ is a product of differentiable functions, so it is differentiable. And for $x<0$ it is also differentiable. Is this correct? (Wondering)
So, we have to check again at $x=0$.
$$\lim_{x\rightarrow 0}\frac{f(x)-f(0)}{x-0}=\lim_{x\rightarrow 0}\frac{x^ae^{-\frac{1}{x^2}} }{x}=\lim_{x\rightarrow 0}x^{a-1}e^{-\frac{1}{x^2}}=0 \text{ for each } a$$ Right? (Wondering)
So, at $x=0$ it is also differentiable with derivative $0$.
For $x>0$ the derivative is $ax^{a-1}e^{-\frac{1}{x^2}}+x^a\frac{2}{x^3}e^{-\frac{1}{x^2}}$.
For $x<0$ the derivative is $0$.
Is everything correct? (Wondering)
At the exercise is says to take cases for $a$ : $a=1$, $a>1$, $a<1$. But why? (Wondering)
I suspect that they are referring to your step "[tex]\lim_{x\to 0^+} x^{a- 1}e^{-\frac{1}{x^2}}= 0[/tex] for all a". That is true but how you prove it is true depend upon whether a< 1, a= 1, or a> 1. That is, they expect you to prove that step.
Ah ok.
So, for $a=1$ we have $$\lim_{x\rightarrow 0}\frac{f(x)-f(0)}{x-0}=\lim_{x\rightarrow 0}\frac{xe^{-\frac{1}{x^2}} }{x}=\lim_{x\rightarrow 0}e^{-\frac{1}{x^2}}=0$$
For $a>1$ we have $$\lim_{x\rightarrow 0}\frac{f(x)-f(0)}{x-0}=\lim_{x\rightarrow 0}\frac{x^ae^{-\frac{1}{x^2}} }{x}=\lim_{x\rightarrow 0}x^{a-1}e^{-\frac{1}{x^2}}=0\cdot 0=0$$
For $a<1$ we have $$\lim_{x\rightarrow 0}\frac{f(x)-f(0)}{x-0}=\lim_{x\rightarrow 0}\frac{x^ae^{-\frac{1}{x^2}} }{x}=\lim_{x\rightarrow 0}x^{a-1}e^{-\frac{1}{x^2}}=\lim_{x\rightarrow 0}\frac{1}{x^{1-a}}e^{-\frac{1}{x^2}}$$ Is this equa to $0$ because the exponential function grows faster that $x^{1-a}$ ? (Wondering)
Yes, the exponential grows faster than any power of x.
Ok. Thank you very much! (Sun)
FAQ: What is the derivative of the given function at all points where it exists?
What is a derivative of a function?
A derivative of a function is a mathematical concept that represents the rate of change of the function at a specific point. It tells us how much the output of a function changes when the input changes by a small amount.
Why is the derivative of a function important?
The derivative of a function is important because it helps us understand the behavior and properties of the function. It can be used to find the maximum and minimum values of a function, determine the slope of a tangent line, and solve optimization problems.
How is the derivative of a function calculated?
The derivative of a function can be calculated using the limit definition of the derivative or through various derivative rules such as the power rule, product rule, quotient rule, and chain rule. These rules allow us to find the derivative of more complex functions without having to use the limit definition every time.
What is the relationship between the derivative and the original function?
The derivative and the original function are closely related. The derivative represents the slope of the tangent line to the original function at a specific point. If the derivative of a function is positive, the function is increasing, and if the derivative is negative, the function is decreasing. Additionally, the derivative can be used to find critical points, which are points where the derivative is equal to zero.
How is the derivative of a function used in real-world applications?
The derivative of a function has many real-world applications, including physics, economics, and engineering. It can be used to model the rate of change of physical quantities, such as velocity and acceleration, and to optimize production processes in economics and engineering. It is also used in financial analysis to calculate the rate of return on investments.
