What is the Derivative of xf(x) at x=4 Using the Product Rule?
  • MHB
  • Thread starter musad
  • Tags
    Derivatives
In summary, the conversation discusses using the product rule to find the derivative of xf(x) when x=4. The solution is obtained by applying the product rule and substituting x=4, resulting in f(x) + x*f'(x).
musad
I am having trouble getting started with this question.
Suppose that f(4)=7 and f′(4)=−2. Use the product rule to find the derivative of xf(x) when x=4. Thanks
It says exactly what to do, use the product rule on $\displaystyle \begin{align*} x\,f(x) \end{align*}$, you should get
$\displaystyle \begin{align*} \left[ x\,f(x) \right] ' &= x' \,f(x) + x\,f'(x) \\ &= 1\,f(x) + x\,f'(x) \\ &= f(x) + x\,f'(x) \end{align*}$
so what do you get when x = 4?
FAQ: What is the Derivative of xf(x) at x=4 Using the Product Rule?
What is the derivative of xf(x) at x=4?
The derivative of xf(x) at x=4 is -2. This means that the slope of the tangent line at x=4 is -2.
How do you find the derivative of xf(x) at x=4?
To find the derivative of xf(x) at x=4, you can use the power rule. First, multiply the coefficient (x) by the exponent (1) to get 1x. Then, subtract 1 from the exponent to get 0. Finally, the derivative is the coefficient (1) multiplied by the new exponent (0), which is 1*0=0. Therefore, the derivative of xf(x) at x=4 is 0.
What does a derivative of -2 mean?
A derivative of -2 means that the slope of the tangent line at x=4 is -2. This means that the function f(x) is decreasing at x=4, since the slope is negative.
What is the relationship between the derivative and the original function?
The derivative of a function f(x) at a specific point x is the instantaneous rate of change of the function at that point. In other words, it represents the slope of the tangent line at that point. Therefore, the derivative of xf(x) at x=4 is a way to describe the slope of the original function at x=4.
Can you graph the derivative of xf(x) at x=4?
Yes, you can graph the derivative of xf(x) at x=4 by plotting a point at (4,-2) on a coordinate plane. This point represents the slope of the tangent line at x=4. You can also graph the original function f(x) and see how the slope changes at x=4.
