What is the difference between AA and AAA batteries?
In summary: AA cells.In summary, AA and AAA batteries differ in physical size and energy storage capacity. They have the same voltage of 1.5V for alkaline cells, but AA batteries generally have a higher energy storage capacity than AAA batteries. The voltage of 3 AAA batteries will be around 4.5V and 4 AA batteries will be around 6V. However, the current output may vary depending on the battery technology and internal resistance.
sivaswetha
What is the difference between AA and AAA batteries? Will the output voltage of 3 AAA and 4AA be same?
Yes. They have the same voltage, but AA batteries store more energy than AAA.
Ok.thank you
Physical size and energy storage capacity. The voltage on light loads will be the same = 1.5V for alkaline cells.
No. The voltage of 3AAA will be around 4.5V and 4AA will be around 6V.
as will 4 AAA 's
Jumping onto his thread for a question I had, will AA batteries output more current than AAA will?
Caveat being that the OP didn't specify series or parallel wiring, so we can't be sure which is the right answer.
More total energy for sure, more current probably -- that's a function of internal resistance of the battery, which should be lower for the AA.
Likes Karmaslap
Depends on the battery technology, so let's talk alkaline.
The difference between AA and AAA alkaline batteries is the physical size and the capacity, generally measured in milliamp-hours.
The range varies depending on the manufacturer and the battery line.
AA (50ma draw) 1800–2600 mAh
https://en.wikipedia.org/wiki/AA_battery
http://data.energizer.com/PDFs/E91.pdf
AAA (50ma draw) 860–1,200 mAh
https://en.wikipedia.org/wiki/AAA_battery
http://data.energizer.com/PDFs/E92.pdf
The max current capability will be more for a AA given the same battery family (technology and "style")
Likes Karmaslap
Related to What is the difference between AA and AAA batteries?
Both AA and AAA batteries are commonly used in household devices such as remote controls, flashlights, and toys. While they may look similar, there are a few key differences between the two.
1. What do the letters "AA" and "AAA" stand for?
The letters "AA" and "AAA" are simply a standardized way of referring to the size and shape of the battery. "AA" is short for "ANSI AA size", and "AAA" stands for "ANSI AAA size". These sizes were established by the American National Standards Institute (ANSI).
2. How do AA and AAA batteries differ in size?
AA batteries are larger than AAA batteries in both length and diameter. The dimensions of a AA battery are approximately 50.5mm in length and 14.5mm in diameter. In comparison, AAA batteries are about 44.5mm in length and 10.5mm in diameter.
3. Do AA and AAA batteries have the same voltage?
No, AA and AAA batteries do not have the same voltage. AA batteries typically have a voltage of 1.5 volts, while AAA batteries have a voltage of 1.2 volts. This means that AA batteries have a slightly higher power output and can last longer in high-drain devices.
4. Can AA and AAA batteries be used interchangeably?
In most cases, AA and AAA batteries are not interchangeable. This is because they have different sizes, voltages, and capacities. However, some devices may be designed to fit both AA and AAA batteries, and in those cases, they can be used interchangeably.
5. Which type of battery should I use for my device?
The type of battery you should use for your device depends on its specifications and requirements. It is important to always refer to the manual or manufacturer's instructions to determine the correct battery size and voltage for your device. Using the wrong type of battery can potentially damage your device or cause it to not function properly.
  • Electrical Engineering
