What is the difference between additive and multiplicative renormalisations?
  • Thread starter Bobhawke
  • Tags
    Difference
In summary, additive and multiplicative renormalization are two different ways to deal with the fact that chiral symmetry is broken on a lattice.
Bobhawke
144
Some papers I am looking over at the moment mention both additive and multiplicative renormalisations. What is the difference between them?
i guess you should provide a specific reference, but here's a guess.
multiplicative renormalization of a coupling [itex]g[/itex] has a counterterm of the form:
[tex]\delta g= g^af(\lambda_i)[/tex]
for some power [itex]a[/itex], while additive renormalization would be
[tex]\delta g= h(\lambda_i)[/tex]
Here [itex]\lambda_i[/itex] are all the other couplings in the theory. To be general, I include masses as couplings.
An example of the first kind is a fermion mass, while the second kind would be a scalar mass (assuming no SUSY).
In additive renormalization, physicsts wave their hands horizontally; in multiplicative renormalizations, physicsts wave their hands vertically.
Actually Richard Feynman had the funniest description, relating to "hokus pocus" ... Roger Penrose mentions in his massive THE ROAD TO REALITY on page 674:
...so it seems we are still stuck with a divergent expression for the total amplitude of any genuinely quantum process...from a strict matehmatical viewpoint we have got officially "nowhere in the sense that all our expressions are still "mathematically meaningless"...yet good physicsts will not give up so easily...and they were right not to do so...whatever philosophical position is taken...renormalization is an essential feature..of modern QFT...very few theories pass the test of renormalizability and only those that do pass have a chance of being regarded as acceptable for physics...
Wikipedia has quite a discussion at http://en.wikipedia.org/wiki/Renormalization#Renormalizability
The context in which I came across the terms is the following:
It is a paper on lattice QCD. It first discusses how the Wilson term can be added to the fermion part of the Lagrangian to avoid the fermion doubling problem. It then says that this breaks chiral symmetry since the extra term looks like a mass term. It then says
"The quark mass has both multiplicative and additive renormalisations due to the explicit breaking of chiral symmetry by the wilson term"
This should be interpreted precisely as I said in my last post.
Normally fermions are "multiplicatively renormalized" since any fermion mass corrections must be proportional to the mass itself by chiral symmetry. However, since chiral symmetry is explicitly broken on the lattice by removing the fermion tastes, you can now get a term that is NOT proportional to the mass, but proportional to [itex]a^{-1}[/itex]. If we were to take this seriously, we would say that there is a "hierarchy problem" here, just like the Higgs in the standard model; but there really isn't since the whole fermion taste/Wilson term is an artifact of our lattice description and not really there.
Thanks Blechman!
Related to What is the difference between additive and multiplicative renormalisations?
1. What is the main difference between additive and multiplicative renormalisations?
The main difference between additive and multiplicative renormalisations lies in the way they account for the divergences in a physical theory. Additive renormalisation involves adding a constant term to the original equation, while multiplicative renormalisation involves multiplying the original equation by a factor.
2. How do additive and multiplicative renormalisations affect the final results of a physical theory?
Additive renormalisation does not alter the overall structure of the physical theory, but it does affect the numerical values of the parameters. On the other hand, multiplicative renormalisation can change the entire form of the theory, leading to a different physical interpretation.
3. Which type of renormalisation is more commonly used in theoretical physics?
Multiplicative renormalisation is more commonly used in theoretical physics, as it allows for a more systematic and elegant treatment of divergences. It is also more effective in eliminating divergences in quantum field theories.
4. Can additive and multiplicative renormalisations be combined?
Yes, it is possible to combine additive and multiplicative renormalisations to obtain a more comprehensive renormalisation scheme. This is known as the "minimal subtraction" scheme, which is often used in quantum field theory calculations.
5. What are the limitations of using either additive or multiplicative renormalisations?
The use of additive or multiplicative renormalisations can lead to non-physical results if they are not applied carefully. In some cases, a combination of both types of renormalisation may be necessary to obtain meaningful results. Additionally, renormalisation is not a universal solution and may not work for all types of divergences in a physical theory.
