What is the difference between groups SU(n) and SO(n,C)?
In summary: I don't know what you're asking for here. You've been given the definition and a non-real example. You can take ##\begin{pmatrix}z & -w\\ w & z\end{pmatrix}## where ##z^2+w^2=1## to get the whole...
LagrangeEuler
717
What is the difference between groups ##SU(n)## and ##SO(n,\mathbb{C})##? They look completely the same.
Unitary matrices satisfy ##A\cdot \bar A^\tau=1## whereas orthogonal matrices satisfy ##A\cdot A^\tau =1##. There is no complex conjugation in the definition of orthogonal groups.
Likes Infrared
I disagree. If you have complex entries in some matrix then condition ##A \cdot A^T=1## is incorrect. Could you please give me a matrix with complex entries that are not just real and show that the condition ##A \cdot A^T=1## is fine? I do not think that this is possible. For instance
[tex]
\begin{bmatrix}
\cos \theta & -\sin \theta\\
\sin \theta & \cos \theta
\end{bmatrix} [/tex]
if you diagonalise this matrix you will get
[tex]\begin{bmatrix}
e^{i \theta} & 0\\
0 & e^{-i\theta}
\end{bmatrix}[/tex]
end then try to emply condition ##A \cdot A^T=1##. You will see that is not valid.
LagrangeEuler said:
I disagree.
Your personal opinion doesn't change the definition.
A definition can't be incorrect, and as ##\mathbb{R}\subseteq\mathbb{C}## we get ##\operatorname{SO}(n,\mathbb{C}) \neq \{1\}.## Whether this is reasonable is a different question and the reason why we introduced unitary matrices in the complex case. However, some theorems in linear algebra require an algebraically closed field, so it makes sense to allow any field, not just the real numbers.
Have a look at https://www.amazon.com/s?k=Gantmacher+Matrix+theory&ref=nb_sb_noss and argue with Gantmacher whether this is "incorrect". Minor difficulty: he passed away in 1964.
LagrangeEuler said:
[tex]
\begin{bmatrix}
e^{i \theta} & 0\\
0 & e^{-i\theta}
\end{bmatrix}[/tex]
It seems like you have made a mistake in your diagonalization. The matrix you start with does satisfy ##A \cdot A^T=1##, and that property should be invariant under diagonalization, so the matrix you end with should satisfy it too.
It looks fine to me.
The property is not invariant under replacing a matrix with its complex diagonalization.
@LagrangeEuler Why is it a problem that the diagonalized form is no longer in ##SO(n,\mathbb{C})##?
Likes LagrangeEuler
Ah, that's right; it's only invariant for a real diagonalization (which doesn't exist for the rotation matrix given since it has no real eigenvalues).
$$\frac{1}{\sqrt{3}}\left(
\begin{matrix}
2 & -i \\
i & 2
\end{matrix}\right)$$
At WolframAlpha
Likes suremarc
\begin{matrix}
2 & -i \\
i & 2
At WolframAlpha
Yes. But you still need to have a group. Show me that group. An infinite group of matrices like this.
Please see this text.
Infrared said:
It looks fine to me.The property is not invariant under replacing a matrix with its complex diagonalization.
Not a problem. I just ask why some people make a difference between ##SU(n)## and ##SO(n,\mathbb{C})##? Could you please show me the two dimensional representation of group ##SO(n,\mathbb{C})##?
Because they're different groups. The matrix @mfb gave is an element of ##SO(2,\mathbb{C})## but not of ##SU(2)##.
I don't know what you're asking for here. You've been given the definition and a non-real example. You can take ##\begin{pmatrix}z & -w\\ w & z\end{pmatrix}## where ##z^2+w^2=1## to get the whole group.
Likes StoneTemplePython
##\operatorname{SO}(n,\mathbb{C})## is a group.
So? Myself has listed some isomorphisms here:
https://www.physicsforums.com/insights/journey-manifold-su2mathbbc-part/
That does not change the definition of ##\operatorname{SO}(n,\mathbb{K}).## Whether it is a meaningful definition or not depends on the application. Mathematics only requires contradiction-free.
##\varphi\, : \,\operatorname{SO}(2,\mathbb{C})\longrightarrow \operatorname{GL}(2,\mathbb{C})## with ##\varphi(A)(\mathbf{v}):=A\cdot \mathbf{v}.##
It is also needed for the complexification of the orthogonal group in Lie theory.
The fact that you do not like it means nothing. This question has been answered and the debate is becoming ridiculous.
Thread closed.
Likes suremarc
Related to What is the difference between groups SU(n) and SO(n,C)?
1. What is the difference between SU(n) and SO(n,C)?
SU(n) and SO(n,C) are both mathematical groups used in theoretical physics and other fields of science. The main difference between them is that SU(n) is a subgroup of the special unitary group, while SO(n,C) is a subgroup of the special orthogonal group over the complex numbers.
2. How are SU(n) and SO(n,C) related?
SU(n) and SO(n,C) are related through the concept of Lie groups, which are continuous groups of symmetries in mathematics. SU(n) is a subgroup of SO(n,C), meaning that all elements in SU(n) are also elements in SO(n,C), but not vice versa.
3. What is the significance of SU(n) and SO(n,C) in physics?
In physics, SU(n) and SO(n,C) are used to describe symmetries in physical systems. SU(n) is often used to describe the symmetries of quantum systems, while SO(n,C) is used to describe the symmetries of relativistic systems.
4. Can you give an example of a physical system that exhibits SU(n) symmetry?
One example of a physical system that exhibits SU(n) symmetry is the behavior of subatomic particles, such as quarks and leptons. These particles have spin, which is a quantum property that can be described using SU(n) symmetry.
5. How do the representations of SU(n) and SO(n,C) differ?
The representations of SU(n) and SO(n,C) differ in their dimensionality. SU(n) has a finite-dimensional representation, while SO(n,C) has an infinite-dimensional representation. This means that the elements in SU(n) can be described using a finite number of parameters, while the elements in SO(n,C) require an infinite number of parameters.
  • Linear and Abstract Algebra
