What is the difference between lumen efficiency and efficacy in lighting?
  • Thread starter lee123456789
  • Tags
    Efficiency
In summary, the conversation discusses the confusion between two terms - lumen efficiency and efficacy - when analyzing lighting options. The speaker is specifically looking at metal halide and fluorescent lighting and is unsure which value to use when comparing the two. The moderator suggests using lumens per watt as a comparison, but notes that the terms efficiency and efficacy should not be used interchangeably. They both refer to the light output per watt, but efficiency is dimensionless while efficacy is expressed in lumens per watt.
lee123456789
93
[Moderator: Moved from a homework forum. This question is not like most homework.]
Problem Statement: I have been lighting and on lumen efficiency and efficacy.
I have got bit confused between them
Im looking at metal halide and fluorescent.
when googling efficiency and efficacy for both. It give me multuple ball part ranges for them and unsure which to uses.
aswell when googling them. it say metal halide efficiency 75-100 lumen per watt and metal halide efficacy 75-100 lumen per watt. so i have got a bit confused between the two
can somebody help please
thanks
Relevant Equations: None
N/A
just check
so both efficiency and efficacy can be expressed as lumens per watts and percentages
I believe the closeness of the definitions between efficiency and efficacy, and the (apparent) frequent misuse of efficiency in this case makes this difficult to follow. It is not unusual to see dimensionless numbers (efficiency) used in place for efficacy (lumens/watt), or vice versa.
They can, but probably shouldn't be. The terminology for lumens/watt is Luminous Efficacy, rather than lumen (or luminous) efficiency. In either case, don't get bogged down. Use the comparison of lumens/watt if you are trying to compare light output with power input. Efficiency in this case is dimensionless, so it is not exactly the same.
Related to What is the difference between lumen efficiency and efficacy in lighting?
What is lumen efficiency?
Lumen efficiency refers to the measure of how well a light source converts electrical energy into visible light. It is typically measured in lumens per watt (lm/W) and is an indicator of the energy efficiency of a light source.
What is lumen efficacy?
Lumen efficacy is a measure of the amount of visible light emitted by a light source per unit of power consumed. It is typically measured in lumens per watt (lm/W) and is an indicator of the overall performance of a light source.
How are lumen efficiency and efficacy related?
Lumen efficiency and efficacy are closely related, as they both measure the amount of light output per unit of power input. However, efficiency specifically refers to the conversion of electrical energy into visible light, while efficacy takes into account the overall performance of the light source.
What factors can affect lumen efficiency and efficacy?
There are several factors that can impact lumen efficiency and efficacy, including the type of light source (e.g. incandescent, LED, fluorescent), the design and materials used in the light source, and the operating conditions (e.g. temperature, voltage).
How can lumen efficiency and efficacy be improved?
Lumen efficiency and efficacy can be improved through advancements in technology and design, such as using more efficient materials and optimizing the design of the light source. Additionally, proper maintenance and usage of the light source can also help to improve its efficiency and efficacy.
  • Classical Physics
  • Electromagnetism
  • Electrical Engineering
  • General Engineering
