chrisgk
- 4
the result of 6:2(2+1) is 9 or 1?
chrisgk said:the result of 6:2(2+1) is 9 or 1?
skeeter said:question ...
Doen't colon ratio symbol, " : ", behave like a vinculum?
i.e. $a:b+c = \dfrac{a}{b+c}$ ?
reason I ask is Wolfram Alpha interprets 4:5+6 as 4/11
chrisgk said:Who is the difference between the symbols ÷ / :
The result is 9. In this expression, the parentheses indicate that the operation inside should be performed first. Therefore, 2+1 is evaluated to 3, and then the division of 6 by 2 is performed, resulting in a final answer of 9.
To solve this expression, follow the order of operations, which states that operations within parentheses should be performed first. So, start by evaluating 2+1 to get 3. Then, perform the division of 6 by 2 to get a final answer of 9.
The answer to this expression is 9 because of the order of operations. The parentheses indicate that the operation inside should be performed first, resulting in 2+1 being evaluated to 3. Then, the division of 6 by 2 is performed, resulting in a final answer of 9.
Yes, the steps to solving this expression are as follows: 1) Evaluate the operation inside the parentheses to get 3. 2) Perform the division of 6 by 2 to get a final answer of 9.
If you do not use parentheses in this expression, the result may be different. Without parentheses, the expression would be evaluated from left to right, meaning the division of 6 by 2 would be performed first, resulting in a final answer of 1. This is because without parentheses, the operation inside the parentheses is not prioritized. It is important to use parentheses to ensure the correct order of operations is followed and to get the correct answer.
