What is the difference between TIC and alkalinity?
  • Thread starter Thread starter TvEp
    Difference
Total Inorganic Carbon (TIC) and alkalinity are distinct concepts in water chemistry. TIC includes H2CO3 (aqueous CO2), HCO3-, and CO32-, while alkalinity is defined as the capacity of water to neutralize acids, typically expressed as equivalents of CaCO3. The primary difference lies in TIC's inclusion of H2CO3/CO2, whereas alkalinity focuses on HCO3- and CO32-. Alkalinity can also encompass other acid-neutralizing components, such as OH-, depending on the context. Some communities may define alkalinity in terms of Na2O equivalents instead of CaCO3, which affects measurement methods. In practical applications, alkalinity is often determined through neutralization titrations, where the amount of acid needed to reach a specific endpoint indicates the concentration of alkaline substances in the sample. This highlights the variability in how alkalinity can be interpreted and measured based on the compounds present.
TvEp
Hey there,
What is the difference between Total Inorganic Carbon (TIC) content and alkalinity?
When I am reading it says that the TIC consists of:
- H2CO3 / aquous CO2
- HCO3-
- CO32-
And it says that alkalinity consists of all acid-neutralizing compounds, portayed as CaCO3, but consisting of:
- HCO3-
- CO3 2-
Does that mean that the only difference is that the TIC also consists of H2CO3 / CO2 concentration, whereas alkalinity only consists of HCO3- and CO32-.
Are there any other acid-neutralizing components that could add to alkalinity that I am missing?
Chemistry news on Phys.org
Not everybody takes the convention for alkalinity equivalent to CaCO3. Some people expect and use alkalinity equivalent to Na2O.
Thanks. What does that mean concretely for what you are exactly measuring? Does it not remain to be all acid-neutralizing components? So HCO3-, CO3 2- and OH-?
I feel sure about the meaning of Total Inorganic Carbon, but I will avoid saying what this is, exactly. But for the meaning of alkalinity, if you are in a community or group which uses this to mean, "equivalents to sodium oxide", then this would be linked to what one would find if to do a neutralization titration. Something alkaline may be measured and then dissolved in water. An acid titrant is used to neutralize to some desired endpoint, and the number of moles of Hydronium ions can be computed. Then, the amount of Na2O which was titrated can also be computed.
Many compounds may be alkaline and can be neutralized with an acid titrant. Example, Na3PO4. Dissolved in water, the solution takes on a pH higher than 7. Not the same as Na2O, but that does not matter. Take a measured sample, titrate, and just assume you neutralized Na2O.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
