What is the difference between velocity and speed
In summary, Velocity is speed and direction. Speed is magnitude only with no indication of direction. An increase in speed is a positive acceleration and a decrease is a negative one.
mreq
77
I don't understand the difference between them !
Any help ?
Velocity has a magnitude and direction. Speed is magnitude only with no indication of direction.
Velocity is speed and direction. :)
There's no such thing as a "negative direction". An increase in speed is a positive acceleration and a decrease is a negative one.
Bear in mind as well that the speed can remain constant and there will still be an acceleration if the direction changes. For instance, a satellite undergoes perpetual acceleration because it never stops changing direction as it falls around the planet.
edit: Actually, I'm not entirely sure about that last statement. By Einsteinian physics, a curved path through a gravitational field is actually a straight line in curved space, but I think that Newtonian terms apply to this subject.
For straight line motion, positive and negative can define directions with respect to some axis. An acceleration is a vector. If it points in the positive direction, it is positive.
I don't quite follow that, Al. Do you mean that someone can just arbitrarily deem "north" to be positive and "south" to be negative? If so, how do multiple observers decide whose opinion is correct?
(Not trying to be a smart-***; I honestly don't get it.)
No rush for an answer; it's 5:30 am and I've been up for 20 hours. I'm going to sleep now.
Both are correct. Say you define "positive" wherever you happen to be facing. Two people won't disagree on the velocity of a car just because they happen to be facing different directions.
It's just a convention. It's neither correct not wrong.
This is the layman definition of "acceleration". In physics "acceleration" is the time derivative of velocity, not of speed.
They must all use the same convention, of course. You can also just use "north" and "south" themselves to specify the direction of a vector.
But it's quite useful to use positive and negative for one-dimensional problems. For example, for a ball tossed straight up in the air, often "up" is taken as positive and "down" as negative. Makes the algebra easy to do. (But you are free to choose your description of the direction as you please.)
My phrasing might have been ill-advised. I deliberately separated velocity into its two components of speed and direction, but perhaps didn't stress enough that they can't be physically separate from one another. (Nuts! I'm still not expressing myself properly. I think that I'll just go home now. Thanks for the responses, guys.)
FAQ: What is the difference between velocity and speed
What is the difference between velocity and speed?
Velocity and speed are both measurements of how fast an object is moving. However, velocity also takes into account the direction of the object's motion, while speed does not.
Are velocity and speed always the same?
No, velocity and speed are not always the same. Velocity includes both the magnitude and direction of an object's motion, while speed only measures the magnitude.
How are velocity and speed calculated?
Velocity is calculated by dividing the displacement of an object by the time it took to move that distance. Speed is calculated by dividing the distance traveled by the time it took to travel that distance.
Can an object have a high velocity but a low speed?
Yes, an object can have a high velocity but a low speed if it is moving at a high velocity in a specific direction, but its overall speed is low due to a short distance traveled in that direction.
In what situations would it be more useful to measure velocity instead of speed?
Velocity is more useful in situations where the direction of an object's motion is important, such as in sports, navigation, and engineering. Speed is more useful for measuring how quickly an object can cover a distance, such as in races or car speedometers.
