What is the difference in this limit?
In summary: If c = 0, you can't say what the limit will be (if any) without doing some more work.Also, if ##\lim_{x \to a} g(x) = \infty##, then the following will be true.##\lim_{x \to a} \left(f(x) + g(x)\right) = \infty##.But ##\lim_{x \to a} \left(f(x) - g(x)\right)## is indeterminate, as is ##\lim_{x \to a} \frac{f
sylent33
39
Calculate the limit of the function for + and - infinity
L'Hospital
Hello!
I need to calculate the limit of this function ## f(x) = (x^2-9)*e^{-x}## for + and - ## \infty ## Now for + infinity I did this
$$ \frac{(x^2-9)}{e^x} $$ apply L'Hospital since we have infinity divided by infinity; $$\frac{2x}{e^x} $$ Apply L'Hospital again $$ \frac{2}{e^x} $$ the limit is 0. Now for -##\infty## I did exactly the same,getting 0 as my limit but apperently that is wrong.The answer should be ##\infty## and I don't know how.Intuitively that just does not make sense to me because we are simply approching it from a diffrent side but the same value.Some insight would be great,thanks!
Likes Delta2
The initial limit is not of the form infinity over infinity at minus infinity. What does ##e^x## go to?
Likes hutchphd
@sylent33, this means that L'Hopital's Rule cannot be applied for this limit, assuming that's what you did.
Likes hutchphd
Uh okay you are right,if we have minus infinity than the ## e^x ## is not going to infinity but rather to 0,so than we have infinity/0. Now I think that is 0,so I don't need to to use the L'Hopitals rule but,this raises another interesting question.So L'Hopitals rule says we need to get the derivative of both the nummerator and determinator.So let's assume I have a situation infinity/0, can I still apply the L'Hopital rule here?
Infinity/0 is either positive or negative infinity, depending on the sign of the denominator (or undefined if the denominator keeps flipping signs).L'hopital's rule says you need it to be 0/0 or infinity/infinity in order to take both derivatives. You can't just apply it to arbitrary limits.
Likes Delta2 and sylent33
You are right of course infinity/0 is infinity...Making really really silly mistakes.Now since the concept of infinity is very abstract and I know that we cannot consider it a number,but ocassionaly the situation comes in let's say calculating limits of a sequence or a function where we have ## 2 *\infty ## or ##2 * -\infty ## and most of these are usually though in class.But not to long ago I stumbled upon an interesting situation,it was a constant number(negative constant number) times - infinity.Something like this
## -2 * \infty ## and the result was ##-\infty ##.Now I know that we cannot consider infinity to be a number,so I am curious as to how does one approach this,is there a certain method you have to use to evalue this,or is it something you would find on a formula sheet?
Not necessarily. If the denominator is approaching zero through the negative numbers, the limit won't be infinity.
If you have a function whose limit is infinity, what this really means is that the function values get arbitrarily large as the independent variable approaches its limiting value.
So if you're given that ##\lim_{x \to a} f(x) = \infty##, then the following will be true.
##c\lim_{x \to a} f(x) = \infty##, if c is finite and strictly positive.
##c\lim_{x \to a} f(x) = -\infty##, if c is finite and strictly negative.
But ##\lim_{x \to a} \left(f(x) - g(x)\right)## is indeterminate, as is ##\lim_{x \to a} \frac{f(x)}{g(x)}##.
Great answer but I am not sure I get the "if the denominator part is approaching zero through the negative numbers".But than it wouldn't even be infinity/0, but rather infinity/-infinity?
Consider ##\lim_{x\to \infty} 1/(e^{-x})## vs ##\lim_{x\to \infty} 1/(-e^{-x})## In both cases it goes to 1/0, but one is infinity and the other is negative infinity. The sign of 0 is not determined.
Likes sylent33
No, it wouldn't be of the form infinity/-infinity if the denominator is getting close to zero (but is always negative).
I think I get it now,shredder gave an great example
FAQ: What is the difference in this limit?
What is the difference between a limit and a derivative?
A limit is a mathematical concept that describes the behavior of a function as its input approaches a certain value. It is used to determine the value that a function is approaching, rather than the value at a specific point. A derivative, on the other hand, is the instantaneous rate of change of a function at a specific point. It is found by taking the limit of the slope of a secant line as the two points on the line get closer together.
How is a limit calculated?
A limit is calculated by plugging in values that get closer and closer to the desired input value and observing the corresponding output values. The limit is then the value that the function approaches as the input values get infinitely close to the desired input value.
What is the difference between a one-sided limit and a two-sided limit?
A one-sided limit only considers the behavior of a function as the input approaches the desired value from one side, either the left or the right. A two-sided limit, on the other hand, considers the behavior of the function as the input approaches the desired value from both the left and the right. A two-sided limit only exists if the one-sided limits from both sides are equal.
Why are limits important in calculus?
Limits are important in calculus because they allow us to study the behavior of functions at points where they may not be defined or where they may be undefined. They also play a crucial role in finding derivatives and integrals, which are fundamental concepts in calculus.
What is the difference between a limit and a continuity?
A limit is a mathematical concept that describes the behavior of a function at a specific point, while continuity is a property of a function that describes its behavior over an interval. A function is continuous at a point if its limit exists at that point and is equal to the value of the function at that point.
