What is the direction and magnitude of the frictional force?
In summary, a 2,200-kg car moving at a constant speed of 11 m/s down a road with a 14% slope will experience a frictional force of 2,989N, which opposes its motion and is equal to the component of gravitational force along the slope. No coefficient of friction is needed to solve this problem.
jimmyboykun
39
A 2,200-kg car is moving down a road with a slope (grade) of 14% at a constant speed of 11 m/s.
The equation that I'm using is ƩF=ma and friction=μN
the mass is 2200kg
the acceleration is zero because of the constant speed.
I really cannot think of anyway to solve this solution.
The frictional force always opposes the motion, it "eats up" the total energy in the system. To do any calculations with the frictional force we need at least the coefficient of friction μ.
And that the problem, mu is not given. Do I have to find mu in order to move on?
Well for this problem you do not need to find mu. Here are some steps to get you started:
1. Draw a free body diagram on the car.
2. Utilize Newtons Second Law in the x and y directions respectively
3. Algebraic Wizardry, manipulate the equations until you can find the frictional force using values you already know.
ok, but what about the 11m/s, does that velocity come into play?
your question mentions that velocity is constant, and when velocity is constant the net force is always zero. so, here friction is equal to the component of gravitational force along the slope.
P.S. - like Legaldose already mentioned drawing free body diagram always clears out doubt.
ok so I solved the problem, and this is what I did: m*g*sin(7.96) the 7.96 is the reverse tangent.
so 2,200kg*9.81m/s^2*sin(7.96)= 2,989N
would that be considered my magnitude and direction?
Not a big deal, but arctan(.14) ~= 7.97.
thanks, but what about the solution that I solved 2,989N is that solution the magnitude and direction, or if there is there still more?
That formulation can confuse people when thinking about e.g. a car being driven up a slope. It leads them to think that the friction between road and tyre would act down the slope. Better always to write that friction opposes relative motion of the surfaces in contact.
it's the magnitude you have calculated. For direction refer to haruspex's post above.
FAQ: What is the direction and magnitude of the frictional force?
1. What is frictional force?
Frictional force is a force that opposes the motion of an object when it is in contact with another surface.
2. What is the direction of frictional force?
The direction of frictional force is always opposite to the direction of motion or the potential motion of the object.
3. What factors affect the magnitude of frictional force?
The magnitude of frictional force is affected by the types of surfaces in contact, the normal force between the two surfaces, and the roughness of the surfaces.
4. How is the magnitude of frictional force calculated?
The magnitude of frictional force can be calculated using the equation Ff = μN, where μ is the coefficient of friction and N is the normal force between the two surfaces.
5. How does the direction and magnitude of frictional force affect the motion of an object?
The direction of frictional force opposes the motion of an object, while the magnitude of frictional force determines how difficult it is for the object to move. A larger frictional force will make it harder for the object to move, while a smaller frictional force will make it easier.
