What is the direction of rolling friction?
In summary: So the force of friction must be in the backward direction.In summary, the frictional force on the wheel when a forward force is applied to the axle and the wheel does not slide is in the backward direction, as it is responsible for increasing the rotational velocity of the wheel to match the increased velocity of the center of mass. This is in accordance with the rule that friction opposes relative sliding motion at the point of contact.
Raymond Zheng
A forward force on the axle accelerates a rolling wheel on a horizontal surface. If the wheel
does not slide the frictional force of the surface on the wheel is:
A. zero
B. in the forward direction
C. in the backward direction
D. in the upward direction
E. in the downward direction
None.
I've already seen another post on the exact same question, but I'm still unclear as to how the solution is obtained.
If a forward force (force to the right, which we take to be positive) is applied at the axle (simply pushing), then, normally the wheel would just move forward without spinning... but because of friction from the surface, the wheel spins in a clockwise direction, meaning that the direction of friction is backwards (to the left). Answer should be C.
If a torque is applied to the wheel, then the wheel is already spinning. Contact with the surface pushes the wheel in the forward direction. Therefore, in this case, friction is pushing the wheel in the forward direction. Answer should be B.
However, the answer key states that the answer is D...?
I'm wondering if the answer key, or any of my answers, are wrong.
Thanks!
The force that acts upwards is the "normal force" which, in this case, exactly opposes the weight of the wheel.
We would not normally think of this is a friction force - so the answer D is incorrect.
The way to think about it is what would happen without friction - the wheel would slide, and the addition of friction would be to oppose the relative sliding motion at the point of contact. So whichever way the rim would normally slide, the friction is the opposite direction. This is the same rule whether, as in this case, the wheel is being pulled by the axle or in the case often discussed where there is a driving torque applied to the wheel.
The former would happen (say) when your car is being towed and the latter when you step on the gas.
You've tried to work through the above process, but you should try again more slowly.
Likes berkeman
First of all your answer key is definitely wrong, the friction force cannot be upwards (unless you posted the question wrong and it actually asks for the normal force).
Seems to me the correct answer is C, and your justification is almost correct. Because (as it given by the problem statement) the wheel is rolling but does not slide, this essentially means that the velocity of the c.o.m of the wheel is equal to the rotational velocity of the point of contact, for any time t. But the force on the axle (which as given by the statement, is accelerating the wheel, which essentially means it increases the velocity of the c.o.m) increases the velocity of the c.o.m, so something must increase the rotational velocity as well in order to remain equal. That increase in the rotational velocity can only come from the torque of friction (the torque of the force in the axle is zero).
Related to What is the direction of rolling friction?
The direction of rolling friction is the direction opposite to the motion of the object. It is a force that acts in the opposite direction of the rolling motion.
Does rolling friction always act in the same direction?
No, the direction of rolling friction can change depending on the direction of the motion of the object. It always acts in the opposite direction of the motion, but the direction of motion can change depending on the surface or other factors.
How does the direction of rolling friction affect an object's motion?
The direction of rolling friction can slow down or stop an object's motion. It can also change the direction of an object's motion if it is rolling on an uneven surface or if there are other external forces acting on the object.
What is the difference between rolling friction and sliding friction?
Rolling friction occurs when an object rolls on a surface, while sliding friction occurs when an object slides on a surface. The direction of rolling friction is opposite to the motion, while the direction of sliding friction is parallel to the surface.
Can the direction of rolling friction be changed?
Yes, the direction of rolling friction can be changed by changing the direction of motion of the object. It can also be affected by external forces, such as a force pushing or pulling the object in a different direction.
15K
