What is the direction of the velocity vector on the rising side of a cycloid?
  • MHB
  • Thread starter Ackbach
  • Tags
    2015
In summary, the direction of the velocity vector on the rising side of a cycloid is constantly changing and can be in a horizontal direction at certain points. This direction is affected by the shape of the cycloid, its speed of rotation, and its position at a given time. There is a formula to calculate this direction using parametric equations. It is important to understand this direction for practical applications like machinery design and predicting object movement on a cycloid path.
Ackbach
MHB
4,155
92
Here is this week's POTW:
It is known that if you take a circle and roll it without slipping on a flat surface, a single point on the circle traces out the path of a cycloid. Show that the direction of the velocity vector for any point on the rising side of a cycloid is directed toward the highest point on the generating circle.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to greg1313 for his correct answer, which I reproduce below:
The parametric equations for a cycloid are given by
\(\displaystyle x=r(T-\sin T)\)
and
\(\displaystyle y=r(1-\cos T)\)
with \(\displaystyle T\) in radians.
W.L.O.G. let \(\displaystyle r=1\).
\(\displaystyle \frac{dy}{dx}=\frac{\sin T}{1-\cos T}\) -- this is the "slope" of the velocity vector.
The coordinates of the highest point of the generating circle are \(\displaystyle (x,y)=(T,2)\).
The coordinates of the point of the generating circle where it contacts the cycloid are \(\displaystyle (x,y)=(T-\sin T,1-\cos T)\)
The slope of the segment from the point of contact to the highest point of the generating circle is
\(\displaystyle \frac{2-(1-\cos T)}{T-(T-\sin T)}=\frac{1+\cos T}{\sin T}=\frac{\sin T}{1-\cos T}\)
As this is equivalent to \(\displaystyle \frac{dy}{dx}\) the velocity vector points to the highest point of the generating circle (on the rising side of the cycloid).
FAQ: What is the direction of the velocity vector on the rising side of a cycloid?
The direction of the velocity vector on the rising side of a cycloid is constantly changing.
Can the velocity vector on the rising side of a cycloid be in a horizontal direction?
Yes, the velocity vector on the rising side of a cycloid can be in a horizontal direction at certain points.
What factors affect the direction of the velocity vector on the rising side of a cycloid?
The direction of the velocity vector on the rising side of a cycloid is affected by the shape of the cycloid, the speed of the cycloid's rotation, and the position of the cycloid at a given time.
Is there a formula to calculate the direction of the velocity vector on the rising side of a cycloid?
Yes, the direction of the velocity vector on the rising side of a cycloid can be calculated using the parametric equations for a cycloid.
Why is understanding the direction of the velocity vector on the rising side of a cycloid important?
Understanding the direction of the velocity vector on the rising side of a cycloid is important in applications such as designing machinery and predicting the movement of objects on a cycloid path.
