What is the domain and range of y=-0.7x+1.9 and y=0.7x+1.9?
In summary, the function that models each half of the roof is y = -0.7x + 1.9 for the left half and y = 0.7x + 1.9 for the right half. The domain for the left half is -2.7 ≤ x ≤ 0 and the range is 0 ≤ y ≤ 1.9. The domain for the right half is 0 ≤ x ≤ 2.7 and the range is 0 ≤ y ≤ 1.9. When graphed, this represents a triangle with a maximum range of 1.9 and a minimum range of 0, as a side of a triangle cannot be negative. By solving for y = 0
milliex51
State the domain and range of the function that models each half of the roof (triangle)
Y= -0.7x+1.9 (left half)
Y= 0.7x+1.9 (right half)
Why is the answer:
Left half: domain: −2.7≤x≤0 range: 0≤y≤1.9
Right half: Domain: 0≤x≤2.7 range: 0≤y≤1.9
I don't understand.
Haven't you tried graphing this on your calculator?
yes I did, and I don't get how for the domain -2.7 is less than or equal to x less than or equal to 0?
If it's modelling a triangle, then draw a picture.
You'll see that the maximum value of the range is 1.9 (the intersection of the two lines) and the minimum is 0 (because a side of a triangle can't be negative).
Then solve the equations for y=0 and y=1.9 to get the values of the Domains.
FAQ: What is the domain and range of y=-0.7x+1.9 and y=0.7x+1.9?
1. What is the domain of y=-0.7x+1.9 and y=0.7x+1.9?
The domain of both equations is all real numbers, as there are no restrictions on the values that x can take on.
2. What is the range of y=-0.7x+1.9 and y=0.7x+1.9?
The range of both equations is also all real numbers. As x increases or decreases, y will approach positive or negative infinity, respectively.
3. How do you find the domain and range of a linear equation?
To find the domain, you can set the equation equal to 0 and solve for x. To find the range, you can graph the equation and look at the values of y that the line passes through.
4. Can the domain and range of a linear equation change?
No, the domain and range of a linear equation are fixed and will not change unless the equation itself is modified.
5. How does the slope affect the domain and range of a linear equation?
The slope affects the steepness of the line, which in turn affects the range. A larger slope will result in a steeper line and a larger range, while a smaller slope will result in a shallower line and a smaller range.
