MHB What is the domain for ax^(1/3) + b?
  • Thread starter Thread starter mathdad
    Domain
The discussion centers on determining the domain of the function ax^(1/3) + b. Initially, it is suggested that the domain is x ≥ 0 due to the presence of a radical. However, it is clarified that the cube root function is defined for all real numbers, meaning the domain encompasses all real numbers. This distinction is made to highlight that unlike square roots, cube roots can accept negative inputs. Ultimately, the correct domain for the function is confirmed to be all real numbers.
mathdad
Precalculus by David Cohen, 3rd Edition
Chapter 1, Section 1.3.
Question 3b.
Specify the domain.
ax^(1/3) + b
Solution:
x^(1/3) means the cube root of x.
Since there is a radical here, I will say the domain is the radicand > or = 0.
So, x > or = 0.
Yes?
Mathematics news on Phys.org
Question 3b.
Specify the domain.
ax^(1/3) + b
Solution:
So, x > or = 0.
Yes?
as cube root is defined for all real number (-ve number also) so the domain is set of real numbers
You are right. I found the following definition online:
"The domain of a cube root function is the set of all real numbers. Unlike a square root function which is limited to nonnegative numbers, a cube root can use all real numbers because it is possible for three negatives to equal a negative."
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
