Jaccobtw
- 163
- 32
- Homework Statement
- **Disclaimer** I tried to write a more descriptive title but it wouldn't let me write enough characters.
An infinitely long, hollow cylinder of radius 5cm has a charge of 30nC/m. Note that the number I just gave you is not the surface charge density. It is the charge per unit length, but you can use it to get the surface charge density if you want. Since the cylinder is infinite, there are no end caps to consider. What is the Electric Field in N/C at a point 3cm from the axis down the center of the cylinder?
- Relevant Equations
- Gauss' Law
3 cm is inside the cylinder. We can use a gaussian cylinder to enclose the inside of the cylinder up to 3 cm. Because the outer cylinder is infinite there is no flux out of the end caps with the inner cylinder. There is also no charge enclosed in the cylinder. So the electric field 3cm away from inside the enclosed cylinder is zero. Is this correct reasoning or am I missing something here? Thank you
