What is the entropy change of aluminum?
In summary, an experiment involving 240 g of aluminum and 40.0 g of water mixed at different temperatures resulted in a final equilibrium temperature of 65.1°C. The entropy changes for aluminum, water, and the aluminum-water system were calculated to be -21.2 J/K, 24 J/K, and 2.8 J/K, respectively.
KrazyX24
In an experiment, 240 g of aluminum (with a specific heat of 900 J/kgK) at 100°C is mixed with 40.0 g of water (4186 J/kgK) at 20°C, with the mixture thermally isolated.
a: What is the equilibrium temp in C?
b: What is the entropy change of aluminum?
c: What is the entropy change of the water?
d: What is the entropy change of the aluminum-water system?
Q=mC(Tf - Ti)
MwCw(Tf - 20c) + MaCa(Tf - 100c)= 0
S(entropy)= Q/T
Basically I'm kinda stuff trying to solve for the final temp, I get 11.9C but that cannot be right since that means the water-Al system lost heat.
any help is very welcome
Nevermind, solved it just now. T(Final) = CaMa + CwMwTi/CwMw + CaMa
Final temp came out to be 65.1*C.
B: S = (MaCa)ln(Tf/Ti) = -21.2 J/K
C: S = (MwCw)ln(Tf/Ti) = 24 J/K
D: 24-21.2= 2.8 J/K
Mod can close thread...
I would respond by saying that the change in entropy of aluminum can be calculated using the equation S = Q/T, where S is the change in entropy, Q is the heat transferred, and T is the temperature. In this experiment, the aluminum and water are thermally isolated, so no heat is transferred between them. Therefore, the entropy change of aluminum would be zero.
To calculate the equilibrium temperature, you can use the equation Q = mC(Tf - Ti), where Q is the heat transferred, m is the mass, C is the specific heat, Tf is the final temperature, and Ti is the initial temperature. In this case, the heat lost by the aluminum (Q = -Q) must equal the heat gained by the water (Q = +Q). So, you can set up the equation -MaCa(Tf - 100°C) = MwCw(Tf - 20°C) and solve for Tf.
Once you have the final temperature, you can calculate the entropy change of the water using the same equation S = Q/T. Finally, to calculate the entropy change of the aluminum-water system, you can simply add the individual entropy changes of aluminum and water together.
Related to What is the entropy change of aluminum?
1. What is entropy?
Entropy is a measure of the disorder or randomness in a system. It is a thermodynamic property that describes the amount of energy that is unavailable for work in a system.
2. How is entropy change calculated?
The change in entropy of a system can be calculated using the equation ΔS = Q/T, where ΔS is the change in entropy, Q is the heat added or removed from the system, and T is the temperature in Kelvin.
3. What factors affect the entropy change of aluminum?
The entropy change of aluminum is affected by temperature, pressure, and the physical state of the aluminum (solid, liquid, or gas).
4. Why is the entropy change of aluminum important?
The entropy change of aluminum is important because it helps us understand how energy is transferred and transformed in a system. It also plays a role in predicting the direction of chemical and physical processes.
5. How does the entropy change of aluminum compare to other elements?
The entropy change of aluminum is unique to aluminum and cannot be compared to other elements. However, it is generally lower than that of other metals due to aluminum's relatively low melting and boiling points.
