What is the expected time difference for two posts in the same minute?
  • MHB
  • Thread starter anemone
In summary, the conversation discusses finding the sum of all possible values of the expression $\lfloor x\rfloor+\lfloor y\rfloor+\lfloor z\rfloor$, where $x$, $y$, and $z$ are real numbers satisfying specific equations. The solution to this problem is also provided, along with some humor and personal anecdotes from the participants.
anemone
MHB
POTW Director
3,883
115
If $x, y, z$ are real numbers such that $x+y+z=6$, $xy+yz+xz=9$, find the sum of all possible values of the expression $\lfloor x\rfloor+\lfloor y\rfloor+\lfloor z\rfloor$.
Mathematics news on Phys.org
Re: Evaluate ⌊x⌋+⌊y⌋+⌊z⌋
Since the floor of a real number is at most, but not quite, 1 point lower than the original number, it follows that:
$$3 < ⌊x⌋+⌊y⌋+⌊z⌋ \le 6$$
$$4 \le ⌊x⌋+⌊y⌋+⌊z⌋ \le 6$$
Working out the equations for instance for x=0, x=ε, and x=1-ε (where ε > 0 is an arbitrary small number), shows that the numbers 4, 5, and 6 are all possible.
Therefore the sum of all possible values of ⌊x⌋+⌊y⌋+⌊z⌋ is 4+5+6=15.
[sp]Let $k=xyz$. The polynomial with roots $x,y,z$ is then $\lambda^3 - 6\lambda^2 + 9\lambda - k.$
You can see from the graph that the only values of $k$ for which the equation $k = \lambda^3 - 6\lambda^2 + 9\lambda$ has three real roots are $0\leqslant k\leqslant4.$ As $k$ increases from $0$ to $4$, we can tabulate the values of the roots as follows, where the $+$ and $-$ subscripts mean addtition or subtraction of a small amount (less than $1/2$). $$\begin{array}{c|c|c|c}k&x,y,z & \lfloor x\rfloor,\, \lfloor y\rfloor,\, \lfloor z\rfloor & \lfloor x\rfloor+\lfloor y\rfloor+\lfloor z\rfloor \\ \hline 0& 0,\,3,\,3 &0,\,3,\,3 & 6 \\ 1 & 0_+,\,3_-,\,3_+ & 0,\,2,\,3 & 5 \\ 2 & 0_+,\,2,\,4_- & 0,\,2,\,3 & 5 \\ 3 & 0_+,\,2_-,\,4_- & 0,\,1,\,3 & 4 \\ 4& 1,\,1,\,4 & 1,\,1,\,4 & 6 \end{array}$$ The only possible values for $\lfloor x\rfloor+\lfloor y\rfloor+\lfloor z\rfloor$ are $4$, $5$ and $6$. If I read the question correctly, it asks for the sum of those values, which is $15.$[/sp]
Edit. I like Serena beat me by just seconds!
We can only see that we posted in the same minute.
Let $x$ be the time I like Serena posted in minutes, and let $y$ be the time Opalg posted.
Then we know that $⌊x⌋=⌊y⌋$ and also that $x<y$.
Therefore $0 < y-x < 60 \text{ s}$.
Note that a smaller amount is more likely, since with higher amounts the probability increases that we'd have posted in different minutes.
The leaves the question what the expected time difference is. ;)
Hey I like Serena and Opalg,
Thank you so so much for participating! At first I thought that folks are jaded with me already...:eek: getting bored because I posted almost a challenge a day here without fail. To be completely candid, sometimes, I even ask Mark if it's appropriate for me to keep posting!
Solution which I found along with the problem:
$6=x+y+z$
$3=(x-1)+(y-1)+(z-1)<\lfloor x \rfloor+\lfloor y \rfloor+\lfloor z \rfloor \le \lfloor x+y+z \rfloor=6$
$\therefore \lfloor x \rfloor+\lfloor y \rfloor+\lfloor z \rfloor=4, 5, 6$
and hence $\lfloor x \rfloor+\lfloor y \rfloor+\lfloor z \rfloor=4+5+6=15$.
Note that a smaller amount is more likely, since with higher amount the probability increases that we'd have posted in different minutes.
I laughed out loud (more than once) when I read this, I like Serena, you have a wonderful personality and a sense of humor!
FAQ: What is the expected time difference for two posts in the same minute?
1. What does the expression ⌊x⌋ + ⌊y⌋ + ⌊z⌋ mean?
The expression ⌊x⌋ + ⌊y⌋ + ⌊z⌋ is a mathematical expression that represents the sum of the floor values of three variables, x, y, and z. The floor value of a number is the largest integer that is less than or equal to that number. For example, the floor value of 3.8 is 3, and the floor value of -2.3 is -3.
2. What is the purpose of evaluating ⌊x⌋ + ⌊y⌋ + ⌊z⌋?
The purpose of evaluating ⌊x⌋ + ⌊y⌋ + ⌊z⌋ is to find the sum of the floor values of three variables. This can be useful in various mathematical and scientific calculations, such as when dealing with discrete data or when approximating real-world values to whole numbers.
3. How do you evaluate ⌊x⌋ + ⌊y⌋ + ⌊z⌋?
To evaluate ⌊x⌋ + ⌊y⌋ + ⌊z⌋, you first need to find the floor value of each variable, x, y, and z. Then, you simply add these floor values together to get the final result. For example, if x = 3.8, y = -2.3, and z = 5.4, then the floor values would be 3, -3, and 5, respectively. The sum of these floor values would be 3 + (-3) + 5 = 5.
4. Can ⌊x⌋ + ⌊y⌋ + ⌊z⌋ be simplified further?
It depends on the values of x, y, and z. In some cases, the sum of the floor values may be simplified further using algebraic or mathematical techniques. However, in most cases, ⌊x⌋ + ⌊y⌋ + ⌊z⌋ cannot be simplified any further and is considered the simplest form of the expression.
5. What happens if one of the variables, say x, is not a whole number?
In this case, the floor value of x would be a decimal or fraction. For example, if x = 3.8, then the floor value of x would be 3. When evaluating ⌊x⌋ + ⌊y⌋ + ⌊z⌋, you would use this floor value of x in the calculation. So, if y = -2.3 and z = 5.4, the sum would be 3 + (-3) + 5 = 5. This means that the result of ⌊x⌋ + ⌊y⌋ + ⌊z⌋ would still be a whole number, even if one of the variables is not.
