What is the expression for |c_n| in terms of the given matrice?
In summary, the conversation discussed a matrix, c_n, which is a 2nx2n matrix given by a specific expression. The determinant of c_n was calculated for n=1,2,3 and a pattern was observed. The conversation also included tips on how to evaluate c_n in general by expanding along the top row and using a recurrence formula. The final conclusion was that the expression for |c_n| is -3^n and an induction proof is needed to verify this.
Petrus
702
Matrice \(\displaystyle c_n\) is a 2nxn2 matrice and is given by \(\displaystyle (\delta_{ij}+2\delta_{i,2n-j+1})_{ij}\) determine the expression of \(\displaystyle |c_n|\)
progress:
I have been drawing the matrice \(\displaystyle n=1,2,3\) and calculate the determinant.
As you see there is a pattern with the matrice and I would like to have tips how i write \(\displaystyle |c_n|\) as a expression cause I got no idé
Regards,
\(\displaystyle |\pi\rangle\)
Petrus said:
Matrice \(\displaystyle c_n\) is a 2x2 matrice and is given by \(\displaystyle (\delta_{ij}+2\delta_{i,2n-j+1})_{ij}\) determine the expression of \(\displaystyle |c_n|\)
First, I assume that $C_n$ is meant to be a $2n\times2n$ matrix (not $2\times2$). Next, you have made a mistake with the matrix $C_1.$ It should be $\begin{bmatrix}1&2 \\ 2&1\end{bmatrix}$, with determinant $-3.$ So $C_1,\,C_2,\,C_3$ have determinants $-3,\,9,\,-27.$ That ought to suggest a pattern.
To evaluate $C_n$ in general, expand along the top row, and I think that you will be able to deduce a recurrence formula relating $C_n$ to $C_{n-1}$.
Thanks for pointing My misstake!
I am trying with \(\displaystyle c_n\) I just Dont get the point with expand along the top row.. It is n big then n-1, n-2..which Dont tell me a lot when I do it.. I mean what I am suposed to see?
Most of the entries in the top row are zero. The only ones you have to worry about are the first and last entries. For each of them, the corresponding cofactor has a column with only one nonzero element; and the cofactor of that element is a copy of $C_{n-1}.$
Sorry to bother you but after doing it once I got
\(\displaystyle c_n= 1•(n-1)-2(n-1)\) what I am suposed to see? I am just having hard to understand. Or is this wrong?
Regards,
Regards,
When you expand the matrix $A = (a_{ij})$ along the top row, the formula is $\det(A) = a_{11}B_{11} - a_{12}B_{12} +\ldots + (-1)^na_{1n}B_{1n},$ where $B_{ij}$ is the cofactor of $a_{ij}.$ What that means is that $B_{ij}$ is the determinant of the $(n-1)\times(n-1)$-matrix obtained by deleting row $i$ and column $j$ from $A$. In the case of your matrix $C_2$, that tells you that $$\begin{vmatrix}1&0&0&2 \\ 0&1&2&0 \\ 0&2&1&0 \\ 2&0&0&1 \end{vmatrix} = 1*\begin{vmatrix}1&2&0 \\ 2&1&0 \\ 0&0&1 \end{vmatrix} - 2*\begin{vmatrix}0&1&2 \\ 0&2&1 \\ 2&0&0 \end{vmatrix}.$$ If you expand each of those $3\times3$-determinants along the bottom row, you see that $\det(C_2) = 1*\det(C_1) - 4*\det(C_1) = -3\det(C_1).$
Is that -4 suposed to be -2? I think I start to understand
Regards,
No, it's supposed to be a -4. We have:
$\begin{vmatrix}1&2&0\\2&1&0\\0&0&1 \end{vmatrix} = 0 \ast (-1)^{3+1}\ast \begin{vmatrix}2&0\\1&0 \end{vmatrix} + 0 \ast (-1)^{3+2} \ast \begin{vmatrix}1&0\\2&0 \end{vmatrix} + 1 \ast (-1)^{3+3} \ast \begin{vmatrix}1&2\\2&1 \end{vmatrix}$
$= 0 + 0 + 1 \ast \det(C_1)$
While:
$\begin{vmatrix}0&1&2\\0&2&1\\2&0&0 \end{vmatrix} = 2 \ast (-1)^{3+1}\ast \begin{vmatrix}1&2\\2&1 \end{vmatrix} + 0 \ast (-1)^{3+2} \ast \begin{vmatrix}0&2\\0&1 \end{vmatrix} + 0 \ast (-1)^{3+3} \ast \begin{vmatrix}0&1\\0&2 \end{vmatrix}$
$= 2 \ast 1 \ast \det(C_1) + 0 + 0$
So that:
$1 \ast \begin{vmatrix}1&2&0\\2&1&0\\0&0&1 \end{vmatrix} - 2 \ast \begin{vmatrix}0&1&2\\0&2&1\\2&0&0 \end{vmatrix}$
$= \det(C_1) - 2 \ast 2 \ast \det(C_1) = -3\det(C_1) = (-3)(-3) = 9$
Hello!
After taking a brake from this problem and finally got back to it things start to make sense!
so we got for \(\displaystyle |c_6|=-3|c_4|\) and \(\displaystyle |c_4=9=-3•-3\) Ahh we see a pattern!
\(\displaystyle |c_n|=-3^n\) ok now we have to do a induction proof for this and does anyone got tips well I pretty much Dont know how this induction proof Will work for this
Regards,
First, we must establish the base case for $n = 1$. Although this is typically very easy, it is most important.
Now:
$|C_1| = \begin{vmatrix}1&2\\2&1 \end{vmatrix} = (1)(1) - (2)(2) = 1 - 4 = -3 = (-3)^1$
Assume that $|C_{n-1}| = (-3)^{n-1}$ (this is our inductive step, we seek to prove given this that $|C_n| = (-3)^n$).
Now to do this, we are going to have to go back "two sizes" (from $2n \times 2n$ to $2(n-1) \times 2(n-1)$).
We have (expanding by minors along the first row):
$|C_n| = 1 \ast |C_{1|1}| - 2 \ast |C_{1|2n}|$
(by $C_{i|j}$ I mean the matrix formed by deleting row i and column j from $C_n$).
since all the other cofactors are 0.
Now in $C_{1|1}$, if we expand THIS determinant by minors along its LAST row (which is all 0's except for the final 1), we get:
$|C_{1|1}| = (-1)^{(2n-1)+(2n-1)} \ast |C_{n-1}| = |C_{n-1}|$.
Similarly, if we expand $|C_{1|2n}|$ by minors along its last row (which is all 0's except for the initial 2), we get:
$|C_{1|2n}| = (-1)^{1+(2n-1)} \ast 2 \ast |C_{n-1}| = 2 \ast |C_{n-1}|$.
Therefore, $|C_n| = 1 \ast |C_{n-1}| - 2 \ast 2 \ast |C_{n-1}| = |C_{n-1}| - 4 \ast |C_{n-1}| = -3 \ast |C_{n-1}|$.
Since by our induction hypothesis:
$|C_{n-1}| = (-3)^{n-1}$,
$|C_n| = (-3)(-3)^{n-1} = (-3)^{1+(n-1)} = (-3)^n$ QED.
Now:
Hello,
I understand all of the part without one( I want Also to say your explaining Was Really good and it is all logic) why \(\displaystyle n-1\) I mean normaly when I proof it is \(\displaystyle n+1\)
and thank you both for taking your time!
Regrds,
You can do an inductive proof either way, it's largely a matter of style. Technically, it's more logically defensible to prove:
P(n0) and [P(n) --> P(n+1)].
However, for:
P(k0) and [P(k-1) --> P(k)]
to work out the same, all you have to do is take an initial value for "k" of k0+1 (it doesn't really matter "which" natural number you start an inductive proof with, as long as it's true for SOME natural number, although if you start with P(17), for example, you may have to prove more "bases cases", or qualify your result).
In other words, the "first" n in my proof is 2, and I prove the base case for n - 1 = 1.
(it doesn't really make any difference if the "dummy variable" in an inductive proof is labelled "n" or "k" or "n-1" its just a LABEL...what IS important is that we prove that given it's true for some (variable) natural number, that in and of itself proves its true for the NEXT natural number).
Or, to put it another way, the sets:
{n in Z: n is in Z+}
{k-1 in Z: k-1 is in Z+}
are both the same sets (namely, N, the natural numbers (starting with 1)) even though n runs from 1 to infinity in the first set, and k runs from 2 to infinity in the second set.
If you wish to amend my proof replacing the "n-1" with "n" (and some of the consequent changes involving various subscripts and exponents) it's fine with me.
FAQ: What is the expression for |c_n| in terms of the given matrice?
What is a determinant as an expression?
A determinant as an expression is a mathematical concept that represents a square matrix in a single number. It is used to determine whether a system of linear equations has a unique solution, multiple solutions, or no solution.
How is a determinant calculated?
A determinant is calculated using a specific formula depending on the size of the matrix. For a 2x2 matrix, the determinant is found by multiplying the top left and bottom right elements and subtracting the product of the top right and bottom left elements. For a larger matrix, the determinant is calculated using a method called expansion by minors.
What does the determinant tell us about a matrix?
The determinant provides information about the matrix's properties, such as whether it is invertible or singular. It also tells us about the linear independence of the matrix's columns and rows, and the volume of the parallelepiped formed by the vectors in the matrix.
What are the applications of determinants in real-life?
Determinants are used in various fields, including physics, engineering, economics, and computer graphics. They are used to solve systems of linear equations, find the inverse of a matrix, and calculate areas and volumes. In physics, determinants are used to compute the moment of inertia and solve problems related to electrical circuits.
What is the relationship between determinants and eigenvalues?
The determinant of a matrix is directly related to its eigenvalues. The eigenvalues of a matrix are the solutions to the characteristic equation, which can be found by setting the determinant of the matrix minus a scalar equal to zero. Also, the determinant of a matrix is equal to the product of its eigenvalues.
