What is the F/cm^2 for a commercial supercapacitor?
In summary, the F/cm^2 value for commercially available supercapacitors can vary greatly depending on the type of carbon, electrolyte, and measurement techniques used. The reported value of 300mF/cm^2 for graphene-based activated carbon should be interpreted with caution and may not be representative of all supercapacitors on the market.
Phy1
What is the F/cm^2 for a commercially available supercapacitor? Much of the literature is on newer types of carbon, such as graphene, but are commercially available supercapacitors based on activated carbon?
http://www.pnas.org/content/suppl/2015/03/22/1420398112.DCSupplemental
In this article published on March 23, 2015, the F/cm^2 is 300mF/cm^2 (.3F/cm^2) for activated carbon (Table S1, p.16), yet references the information from an older article. The reference is to:
Simon P, Gogotsi Y (2008) Materials for electrochemical capacitors. Nature Materials 7: 845-854.
http://rsta.royalsocietypublishing.org/content/368/1923/3457
The authors of the older article state, "Double-layer capacitance for carbon materials in liquid electrolytes is in the range of 5 to 20 μF cm−2, depending on the electrolyte." in this different but more up to date 2010 article.
I have not unraveled a supercapacitor, but the range of 5 to 20 μF cm−2 seems rather low compared to the small size of supercapacitors commercially available, but is the .3F/cm^2 stated in the more recent article accurate?
it is important to critically evaluate the information presented in research articles and to consider the limitations and potential errors in the reported data. In this case, the discrepancy between the F/cm^2 values reported in the two articles could be due to a variety of factors, such as differences in measurement techniques, electrode design, or electrolyte composition.
Firstly, it is important to note that the F/cm^2 value reported in the more recent article is for a specific type of activated carbon (AC), namely graphene-based AC. This type of carbon has a high surface area and unique structure, which can greatly influence its capacitance compared to other types of AC. Therefore, it is possible that the reported F/cm^2 value may not be representative of all commercially available supercapacitors.
Additionally, the measurement techniques used in the two articles may also contribute to the difference in reported values. The older article mentions using liquid electrolytes, while the more recent article uses a solid-state electrolyte. The type of electrolyte can greatly affect the capacitance of a supercapacitor, as it influences the formation of the electric double layer at the electrode-electrolyte interface. Therefore, it is possible that the F/cm^2 values reported in the two articles are not directly comparable.
Furthermore, it is important to consider the limitations of the techniques used to measure capacitance. Both articles mention using cyclic voltammetry (CV) to determine the capacitance of the carbon materials. However, CV can be affected by factors such as electrode geometry, scan rate, and electrolyte resistance, which can lead to errors in the reported values. Therefore, it is possible that the F/cm^2 values reported in the two articles may be overestimations or underestimations of the true capacitance.
In conclusion, while the F/cm^2 value reported in the more recent article may be accurate for the specific type of activated carbon studied, it is important to consider the limitations and potential sources of error in the reported data. Further research and experimentation may be necessary to determine the true capacitance of commercially available supercapacitors based on activated carbon.
Related to What is the F/cm^2 for a commercial supercapacitor?
1. What is F/cm^2 for a commercial supercapacitor?
The F/cm^2, or Farads per square centimeter, for a commercial supercapacitor refers to the capacitance per unit area of the supercapacitor. It is a measure of the ability of the supercapacitor to store electrical energy.
2. Why is F/cm^2 important for a commercial supercapacitor?
F/cm^2 is important for a commercial supercapacitor because it determines the overall capacity and efficiency of the device. A higher F/cm^2 means that the supercapacitor can store more energy and deliver it more quickly, making it a more effective energy storage solution.
3. How is F/cm^2 measured for a commercial supercapacitor?
F/cm^2 is typically measured using a technique called cyclic voltammetry, which involves applying a voltage to the supercapacitor and measuring the resulting current. The ratio of the voltage change to the resulting current change is then used to calculate the F/cm^2 value.
4. What factors can affect the F/cm^2 of a commercial supercapacitor?
The F/cm^2 of a commercial supercapacitor can be affected by a number of factors, including the materials used in its construction, the design of the electrodes, and the electrolyte solution. Temperature, humidity, and other environmental conditions can also impact the F/cm^2 value.
5. How does the F/cm^2 of a commercial supercapacitor compare to other energy storage options?
The F/cm^2 of a commercial supercapacitor is generally higher than that of traditional batteries, making it a more efficient and faster-charging energy storage option. However, it may have a lower F/cm^2 compared to other supercapacitors or energy storage technologies such as lithium-ion batteries or fuel cells.
9K
  • Sticky
  • Feedback and Announcements
496K
