What is the Factorization and Inequality of a Lagoon's Depth Function?
In summary, the sonar device found the depth of the lagoon in feet, as a function of the horizontal distance, in yards, from the device.
noahpww
Hello Everybody ,
First of all, I would like to apologize that this problem contains 3 parts to it (3 questions) but they all relate to each other. You must complete one part to move on to the next part. With that being said, I have 3-part problem that I could use some assistance with.
1a. Suppose a sonar device is set-up in the middle of a lagoon. The device found the depth of the lagoon in feet, as a function of the horizontal distance, in yards, from the device is given by D(x) = (x² − 4)³ − 5(x² − 4)² + (x² − 4) − 5. Factor the formula for D completely. Do not solve for anything.
I tried factoring this and got D(x) = (x + 3)(x - 3)(x^4 − 8^2 + 17) Is this correct?
1b. Draw and complete a number line for the inequality D(x) > 0.
How would I got about creating a number line for this?
1c. Assuming the lagoon is circular, using the information from your number line in part (b), what is the diameter of the pond?
(A side not for this entire 3-part problem, D(x)=0 is at the surface of the lagoon. Assume the positive direction to be "upwards.")
Mathematics news on Phys.org
Okay, we are given:
\(\displaystyle D(x)=(x^2-4)^3-5(x^2-4)^2+(x^2-4)-5=(x^2-4)^2(x^2-9)+(x^2-9)=(x^2-9)((x^2-4)^2+1)=(x+3)(x-3)(x^4-8x^2+17)\quad\checkmark\)
We see that the factor that's a quadratic in $x^2$ has a negative discriminant, so the only real roots are:
\(\displaystyle x=\pm3\)
So, what you want to do is draw a number line and plot those two real roots on the line, and then pick a test value from one of the resulting intervals to determine the sign of $D$ in that interval. Since both of these roots are of multiplicity 1 (an odd multiplicity) we know the sign of $D$ will alternate across the 3 intervals. I would choose the middle interval, which is $(-3,3)$ and use zero as the test point.
What is the sign of $D(0)$?
Mark,
I'm sorry but I'm confused by this question.
We found that the only real roots of $D$ are at $x=\pm3$, or:
\(\displaystyle D(-3)=D(3)=0\)
This means that as $x$ moves across those two roots, the function $D$ changes sign. So, what I would do is draw a real number line and plot those two roots:
Okay, now we can pick a test value from any 1 of the resulting three intervals:
\(\displaystyle (-\infty,-3),\,(-3,3),\,(3,\infty)\)
For simplicity, I would choose the middle interval and let the test point be $x=0$. Now, we see that if $x=0$, then our factored form of $D$ will have 2 positive factors and a negative factor, which means:
\(\displaystyle D(0)<0\)
Thus, because the sign of $D$ will alternate across the 3 intervals, we know we must have:
The diameter of the lagoon will be the distance between the roots...which is?
Would it be 5 feet since there are 5 intervals between -3 & 3 (-2,-1,0,1,2)?
No it would be the distance from -3 to 3, which is 6 yards. Recall the horizontal distances are in yards, while vertical distances are in feet. :D
We want to factor $$(x² − 4)³ − 5(x² − 4)² + (x² − 4) − 5$$
First put $y=x^2-4$, then we are looking to factor $y^3-5y^2+y-5$, which is obviously zero when $y=5$, so $(y-5)$ is a factor of this. Taking this factor out gives us $$(y-5)(y^2+1)$$
The second bracketed term obviously has no real roots, so when we back substitute $(x^2-4)$ for $y$ in this term, what we have still has no real roots, and so no real factors. Doing the back substitution on the whole thing gives:
$$(x^2-9)[ (x^2-4)^2+1 ]=(x-3)(x+3)[x^4-8x^2+17]$$
Which is a complete factorization as we know the term in the square bracket has no real factors.
Mark,
Oh okay this makes sense. Thank you so much for your help. I really appreciate it!
FAQ: What is the Factorization and Inequality of a Lagoon's Depth Function?
1. What is a polynomial inequality?
A polynomial inequality is an inequality that involves a polynomial expression, which is an expression made up of variables, coefficients, and exponents using the operations of addition, subtraction, and multiplication. An example of a polynomial inequality is 3x² - 5x + 2 > 0.
2. How do you solve a polynomial inequality?
To solve a polynomial inequality, you must first simplify the expression by combining like terms and rearranging the terms so that the inequality sign is on the left side. Then, you must factor the polynomial expression to find the roots, or x-intercepts. These roots will help you determine the intervals where the inequality is true. Finally, you must test a value from each interval in the original inequality to determine the solution set.
3. What is the difference between solving a polynomial equation and a polynomial inequality?
The main difference between solving a polynomial equation and a polynomial inequality is that when solving an equation, the goal is to find the values of the variables that make the equation true. However, when solving an inequality, the goal is to find the values of the variables that make the inequality true, which can be a range of values rather than just a single value.
4. What are some common methods for solving polynomial inequalities?
Some common methods for solving polynomial inequalities include using the graphing method, the interval notation method, and the sign chart method. In the graphing method, you graph the polynomial function and use the x-intercepts to determine the solution set. In the interval notation method, you use the intervals determined by the roots to write the solution set in the form of intervals. In the sign chart method, you create a chart to analyze the sign of the polynomial expression in different intervals to determine the solution set.
5. How can polynomial inequalities be applied in real life?
Polynomial inequalities can be applied in real life in various fields, such as economics, physics, and engineering. For example, in economics, polynomial inequalities can be used to model supply and demand functions to determine the optimal production level for a company. In physics, polynomial inequalities can be used to model the trajectory of a projectile or the speed of an object in motion. In engineering, polynomial inequalities can be used to optimize the design of a structure based on various constraints and limitations.
