What is the final speed of the boat?
In summary, Jack and Jill are maneuvering a 3570kg boat near a dock. Initially, the boat's position is (2,0,9) and its speed is 4.6m/s. As the boat moves to position (12,0,0), Jack exerts a force of (-80*10)N, and Jill exerts a force of 0N. The final speed of the boat is 9.6m/s.
Westin
87
Jack and Jill are maneuvering a 3570kg boat near a dock. Initially the boat's position is [PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char68.png2,0,9[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char69.pngm and its speed is 4.6m[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmmi10/alpha/144/char3D.pngs. As the boat moves to position [PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char68.png12,0,0[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char69.pngm, Jack exerts a force of [PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char68.png-80,0,290[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char69.pngN, and Jill exerts a force [PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char68.png0,240,0[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char69.pngN.
What is the final speed of the boat?[/B]
W=Fd
Kfinal = Kinitial +W
KE=(1/2)mv^2[/B]
1) Final total work
Jack Work = (-80*10)+(0*0)+(290*-9) = -3410
Jill Work = 0
(It says my Work is correct)
2) Kfinal = Kinitial + W
Kinitial = (1/2)(3570)(4.6)^2 = 37770.6
Kfinal = 37770.6+(-3410)
Kfinal = 34360.6
3) Final Velocity = KE/m
34360.6/3570 = 9.6248m/s
Not sure where my error is... any help would be appreciated!
[/B]
This is not the correct relation between velocity and KE.
I was able to get the worst answer, I just plugged final KE back into K= 1/2mv^2 and solved for v.
The second part of the question asks... Which person exerted a force perpendicular to the displacement of the boat?
a) Neither Jack nor Jill.
b) Both Jack and Jill.
c) Jill
d) Jack.
I thought it was Jack since Jack is the only person exerting Work. But then I thought Jill because she's exerting force, but just in the wrong direction (perpendicular?) so her work is 0. I only have one shot at this, is my reasoning ok for saying its Jill?
Have you covered the "dot product" or "scalar product" of two vectors? If so, you probably covered how to use the dot product to test if two vectors are perpendicular.
If you are not familiar with the dot product, then can you sketch the two force vectors and the displacement vector on a x,y, z coordinate system?
Related to What is the final speed of the boat?
1. What is the definition of final speed?
Final speed refers to the velocity of an object at the end of its motion or after all external forces on it have ceased.
2. How is the final speed of a boat calculated?
The final speed of a boat can be calculated by dividing the distance traveled by the time it took to cover that distance. This is known as the average speed formula: final speed = distance / time.
3. What factors affect the final speed of a boat?
The final speed of a boat can be affected by factors such as the force of the boat's engine, wind and water resistance, and the weight and shape of the boat.
4. Can the final speed of a boat be greater than its initial speed?
Yes, the final speed of a boat can be greater than its initial speed if the boat is accelerating or if there is a strong current or wind pushing it forward.
5. How does the final speed of a boat relate to its kinetic energy?
The final speed of a boat is directly related to its kinetic energy, as kinetic energy is dependent on the mass and velocity of an object. The faster the boat is moving, the more kinetic energy it has.
