What is the Force Constant k of a Spring?
In summary, a 4.50 ✕ 10^5 kg subway train comes to a stop from a speed of 0.500 m/s in 0.900 m with the help of a large spring bumper. The force constant k of the spring can be calculated using the formula k=mg/x. However, since the attempt at a solution did not yield the correct answer, the concept of potential energy of a spring was brought up. Using the equation PE = (.5)kx^2, the initial kinetic energy of the train can be calculated and it is 0 since the train comes to a complete stop. This is due to the conservation of potential energy, where the initial potential energy is equal to the final energy
ImmaGrump
A 4.50 ✕ 10^5 kg subway train is brought to a stop from a speed of 0.500 m/s in 0.900 m by a large spring bumper at the end of its track. What is the force constant k of the spring?
M- 4.50E5 kg
IV- .5m/s
FV- 0m/s
k=mg/x
F=-kx
PE = (.5)kx^2
k=(450000kg)(9.81m/s^2)/ .9 = 4900000, which isn't the right answer. Can someone help me out?
Have you read anything about the concept of potential energy of a spring?This question is directly based on that..
The kinetic energy of the train is being converted in the potential energy of spring?
Well I know PE = (.5)kx^2, but I am afraid I don't know how to plug in the numbers.
What's the intial kinetic energy (KE) of the train?
KE will = 0 when v = 0 (why is this true?)
Due to conservation of potential energy, initial(KE+PE) = final(KE+ E)
The force constant, k, of a spring is a measure of its stiffness or how much force is required to stretch or compress the spring by a certain distance. It is typically measured in units of Newtons per meter (N/m).
To solve this problem, we can use the formula F=-kx, where F is the force exerted by the spring, k is the force constant, and x is the distance the spring is stretched or compressed. In this scenario, the force exerted by the spring is equal to the force required to bring the train to a stop, which is the product of its mass and acceleration. So we can write:
F = ma = (4.50E5 kg)(0.5 m/s^2) = 225000 N
Substituting this into the formula F=-kx, we get:
225000 N = -k(0.900 m)
Solving for k, we get:
k = 225000 N / 0.900 m = 250000 N/m
So the force constant of the spring is 250000 N/m.
Related to What is the Force Constant k of a Spring?
1. What is the definition of the Force Constant k of a Spring?
The Force Constant k of a Spring is a measure of the stiffness of a spring, and it relates the force applied to the displacement of the spring from its equilibrium position. It is essentially a measure of how much force is required to stretch or compress a spring by a certain distance.
2. How is the Force Constant k of a Spring calculated?
The Force Constant k of a Spring can be calculated by dividing the force applied to the spring by the displacement it experiences. This can be represented by the equation k = F/x, where k is the Force Constant, F is the applied force, and x is the displacement.
3. What is the unit of measurement for the Force Constant k of a Spring?
The unit of measurement for the Force Constant k of a Spring depends on the units used for force and displacement. In the SI system, the unit for force is Newtons (N) and the unit for displacement is meters (m), therefore the unit for the Force Constant k would be N/m.
4. How does the Force Constant k of a Spring affect the behavior of the spring?
The Force Constant k of a Spring determines the stiffness of the spring and therefore affects its behavior. A higher Force Constant k means the spring is stiffer and requires more force to stretch or compress, while a lower Force Constant k means the spring is less stiff and requires less force to stretch or compress.
5. Can the Force Constant k of a Spring change?
Yes, the Force Constant k of a Spring can change depending on factors such as the material and thickness of the spring, temperature, and external forces applied to the spring. However, for a specific spring, the Force Constant k will remain constant as long as there are no changes in these factors.
