What is the force on a moving particle in a magnetic field?
In summary, at 134 μs after it entered the region, the particle had a velocity of 3855.7 m/s and a negative charge of -1.58E-4.
acdurbin953
42
A charged particle of mass m = 6.9E-8 kg, moving with constant velocity in the y-direction enters a region containing a constant magnetic field B = 1.7T aligned with the positive z-axis as shown. The particle enters the region at (x,y) = (0.99 m, 0) and leaves the region at (x,y) = 0, 0.99 m a time t = 402 μs after it entered the region.
What is Fx, the x-component of the force on the particle at a time t1 = 134 μs after it entered the region containing the magnetic field.
F=QvB
d=vt
Solved for the velocity and got v=3855.7 m/s.
Solved for charge and got -1.58E-4
Then using d=vt, I solved for how far along the circular motion path the particle would be at t1, and got 0.516. Then I used θ=s/r=0.52/0.99 to get the angle in radians (0.52) and then converted to degrees and got 29.8° (I used an online converter just to be sure). From there I used F=QvBsin(θ). The answer was wrong, and so I plugged in that answer into the next question asking for Fy and it was wrong also.
how did you solve for velocity?
How did you solve for the charge?
For velocity: d=πr/2=1.55 then d/t=v. 1.55/402μS=3855.7 m/s. That part was marked correct.
For charge I used Q=vm/rB by relating F=QvB and F=ma. Then used right hand rule to determine that the charge was negative. That part was marked correct also.
Hmmm... so you're looking for the force components?
One thing you need to realize is this: s/r = theta gives you the angle of the subtended arc. That is, the fraction of the circle that you traversed. The theta in your f=qvbsin(theta) is the angle between your velocity and the field. It comes from the cross product (not sure if that's in your scope or not).
This gives you the magnitude of the force, the direction of the force is perpendicular to the velocity and the field simultaneously, always.
Yes, looking for force components.
Oh, I didn't make that connection. So the angle would just be 90° then if it's always perpendicular?
The velocity and field are not necessarily perpendicular, but the resultant force is always perpendicular to both. (with 2 lines, you can always lay a piece of paper down so that both lines are on the paper), the force is then either into or out of the paper.
Related to What is the force on a moving particle in a magnetic field?
The force on a moving particle in a magnetic field is known as the Lorentz force. It is a result of the interaction between the magnetic field and the charged particle's velocity. It can be calculated using the equation F = qvBsinθ, where q is the charge of the particle, v is its velocity, B is the magnetic field strength, and θ is the angle between the particle's velocity and the direction of the magnetic field.
How does the direction of the magnetic field affect the force on a moving particle?
The direction of the magnetic field affects the force on a moving particle in two ways. First, the force is always perpendicular to both the particle's velocity and the direction of the magnetic field. Second, the direction of the force depends on the charge of the particle and the direction of its motion relative to the magnetic field. A positive charge will experience a force in one direction, while a negative charge will experience a force in the opposite direction.
How does the velocity of the particle affect the force in a magnetic field?
The velocity of the particle affects the force in a magnetic field in two ways. First, the magnitude of the force is directly proportional to the particle's velocity. This means that a faster-moving particle will experience a stronger force. Second, the direction of the force depends on the angle between the particle's velocity and the direction of the magnetic field. If the particle is moving parallel to the magnetic field, it will not experience any force.
What is the relationship between the charge of the particle and the force in a magnetic field?
The charge of the particle has a direct relationship with the force in a magnetic field. A higher charge will result in a stronger force, while a lower charge will result in a weaker force. This can be seen in the equation for the Lorentz force, where the charge (q) is a factor in calculating the force (F).
Can the force on a moving particle in a magnetic field be changed?
Yes, the force on a moving particle in a magnetic field can be changed by altering the strength or direction of the magnetic field. Additionally, the force can be changed by altering the velocity or charge of the particle. By changing any of these factors, the magnitude and direction of the force can be adjusted accordingly.
