What is the formula for the $n$th term of the interesting sequence?
In summary, the sequence $1, 2, 2, 3, 3, 3, 4, 4, 4, 4, 5, 5, 5, 5, 5, 6, 6, 6, 6, 6, 6, ...$ can be represented by $a_n=\lfloor\sqrt{2n}+\frac{1}{2}\rfloor$, where $n$ is the position in the sequence. This can be proven by using the triangular numbers to show that the sequence increments at the same positions as the expression $\sqrt{2n} + 1/2$, thus making the floor of the expression equivalent
alexmahone
304
Let $a_n$ be the $n$th term of the sequence $1, 2, 2, 3, 3, 3, 4, 4, 4, 4, 5, 5, 5, 5, 5, 6, 6, 6, 6, 6, 6, ...,$ constructed by including the integer $k$ exactly $k$ times. Show that $a_n=\lfloor\sqrt{2n}+\frac{1}{2}\rfloor$.
(Hints only as this is an assignment problem.)
Hint: when does the $k$th digit first and last appear in the sequence? Use the triangular numbers.
The integer $k$ first appears at the $\left[\dfrac{(k-1)k}{2}+1\right]$th position and last appears at the $\left[\dfrac{(k-1)k}{2}+k\right]$th position.
Not sure where to go from here.
So that tells you that the sequence increments immediately after every index of the form $n = (k - 1)k/2 + k = k(k + 1)/2$, and nowhere else, right? So if you can show that the expression you are given $\sqrt{2n} + 1/2$ increments for exactly the same $n$'s, then the floor of that must be equivalent to your sequence.
FAQ: What is the formula for the $n$th term of the interesting sequence?
What is an interesting sequence?
An interesting sequence refers to a series of numbers or objects that follow a specific pattern or rule. This pattern can be observed and often leads to interesting mathematical or scientific discoveries.
How is an interesting sequence different from a regular sequence?
An interesting sequence typically has a unique pattern or rule that sets it apart from a regular sequence. This can make it stand out and catch the attention of scientists or mathematicians.
What are some examples of interesting sequences?
One famous example is the Fibonacci sequence, where each number is the sum of the previous two numbers (1, 1, 2, 3, 5, 8, 13, etc.). Another example is the prime number sequence (2, 3, 5, 7, 11, 13, etc.), where each number is only divisible by 1 and itself.
How are interesting sequences used in science?
Interesting sequences can be used in a variety of scientific fields, such as biology, chemistry, physics, and more. They can help researchers understand patterns and relationships in data, make predictions, and discover new principles or laws.
Can anyone find an interesting sequence?
Yes, anyone can potentially find an interesting sequence by observing patterns in numbers or objects. However, it often takes a trained eye and a deep understanding of mathematics or science to recognize the significance of a sequence and its potential implications.
